09-17-2013, 08:30 PM | #1 |
Directional lights
Greetings, I have a Brewster bodied, on a 34 ford V8 Chassis. I do not have directional signals. Since the harness on the 34 is so similar to the Model A, has anyone used the harness for the model A that uses your headlight and tail light as directionals? Or does anyone know if such an item is currently available?
I do not want to attach aftermarket lights, my car is in excellent original condition (46k original miles, CCCA national first) I have steering wheel light switch, seems identical to the Model A. My car has same dual filament headlight bulb as Model A, harness pattern looks identical. Any input would be appreciated. Thank you |
09-18-2013, 01:02 AM | #2 |
Re: Directional lights
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
