Old 11-14-2020, 04:33 PM   #1
Blastfromthepast
Default 1936 oil weight suggestions
What weight oil weight is suggested for 1936 ford.
Blastfromthepast is offline   Reply With Quote
Old 11-14-2020, 04:54 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: 1936 oil weight suggestions
I run Shell Rotella 15/40 in my stock original engine. Probably 12000 since rebuild. I run it hard at times. No filter. I change oil every 1000 miles.
Cheers
Tony
Old 11-14-2020, 05:35 PM   #3
Blastfromthepast
Thanks, KiWinUS I’m thinking maybe 10w40?
I like the grill. I have the same pines grill. Blast.
Old 11-14-2020, 05:44 PM   #4
JWL
It depends. If the engine is new, 10-30 is appropriate. If well used 20-50 would be a good choice. It is a good practice to change regularly at about 1000 miles.
JWL is offline   Reply With Quote
