10-02-2021, 12:59 AM | #1 |
timing for a b cam with original gear in a standard 1929 A
timing for a B cam with it's original gear, in a standard 1929 A. is it 9 degrees advanced?
10-02-2021, 01:22 AM | #2 |
Re: timing for a b cam with original gear in a standard 1929 A
No, just time it like any stock Model A
10-02-2021, 05:45 AM | #3 |
Ignition timing is dictated basically by the style of front cover [pin location].
10-02-2021, 06:08 AM | #4 |
Assuming that your engine has a Model "A" timing gear cover, time the ignition as you would for the Model "A" at TDC. Before timing, pull the spark lever down 2 or 3 notches.
Bob Bidonde |
10-02-2021, 10:40 AM | #5 |
10-02-2021, 11:14 AM | #6 |
10-02-2021, 01:53 PM | #7 |
Thanks
10-02-2021, 03:29 PM | #8 |
I have the same question. Please explain. Maybe i missed something???
Ruth "Sometimes you really DO need to read the whole thread" |
10-02-2021, 04:21 PM | #9 |
A Madeleines B cam in a model A doesn't need any different tune up requirements than an A cam.
10-03-2021, 04:38 AM | #10 | |
The B distributor needs the 9 degrees initial advance as the auto advance mechanism only has 8.5 degrees advance I gather. http://www.fordgarage.com/pages/bdistributoradvance.htm |
10-03-2021, 05:49 AM | #11 |
Yep, the B distributor has been discussed recently. Ford didn't get it right. That advance system only gives about 20* if that. So the base timing needs to be set at 19* which is where the B cover timing pin is. [ This is crank degrees]
10-03-2021, 06:07 AM | #12 |
I have a GAZ cam in my car and I time it exactly like a regular Model A. Except that I move the lever down one notch (4 degrees). That way I am assured that if I have to hand crank the car it will not try to start backwards and possibly injure me. My running setting is 3 notches from full advance.
