Old 07-17-2021, 04:36 PM   #1
Cape Codder
Cape Codder's Avatar
Default Front Axle Markings
How does one tell the difference between an "A" axle and an "AA" axle? I have one that has "AA" markings on it and when matched to the axle that I removed it looks 1" - 1 1/4" shorter but when measuring center to center on the the King Pin Holes they are within 1/16".
Does anyone have printed specifications available for the front axle that would care to share?
Cape Codder is online now   Reply With Quote
Old 07-17-2021, 05:02 PM   #2
jw hash
jw hash's Avatar
Default Re: Front Axle Markings
the early A`s and double A`s used the same front axles, then they went to bigger king pins, so if it is marked AA check the king pin holes
jw hash is offline   Reply With Quote
Old 07-18-2021, 01:43 PM   #3
Kevin in NJ
The AA and EE are engineering designations for the type of metal used.
Kevin in NJ is offline   Reply With Quote
Old 07-18-2021, 02:20 PM   #4
Cape Codder
Thanks Kevin
