07-27-2021, 07:38 AM | #1 |
Anyone Ever Repair A....
Hi guys I have a question on the Zenith Carb. ... has anyone ever stopped the leaking drain cock on the side bowel. I replaced the drain valve with new ones, all you need to do is try and tighten them with a plyers and there done, but i was wondering if it can be pluged up some how?? it is a special thread and i couldn't find a plug to fit.I was thinking of retaping it out to a standard small pipe thread , is that the way to go ?? I have a new side bowel on order from Brattons , with yet another drain cock but just for my own info. i would like to plug up the old one. thanks again THE HOOCH
07-27-2021, 09:42 AM | #2 |
Re: Anyone Ever Repair A....
It would be pipe thread from the factory, unless someone goofed it up later. Pliers! Suggest you get a proper wrench on the part, so you don't round over the flats. I use gas proof pipe dope on my fittings.
07-27-2021, 10:33 AM | #3 |
See attached article.
Tom Endy |
07-27-2021, 12:55 PM | #4 |
Ive never run into that problem as long as you use the gaskets as Tom shows!
www.whidbeymodelaclub.com |
07-27-2021, 01:13 PM | #5 |
What material were the 2 gaskets made from originally? Are they both made from the same material?
07-27-2021, 01:28 PM | #6 |
07-27-2021, 01:41 PM | #7 |
If you want to plug up the petcock. Why don't you just braze up the tip, re-dress it and seat it down.
Have you looked at the seat in the sediment bowl. Is it damaged? |
07-27-2021, 07:09 PM | #8 |
Some of the reproduction parts do not fit correctly. No surprise there. Bolt too long, sides of the casting not parallel, screen too long.
Tom Endy |
Thread Tools | |
Display Modes | |
