Old 12-30-2020, 11:33 AM   #1
alexiskai
alexiskai's Avatar
Default Compressed head gasket thickness, for the record
I'm working up the instructions for calculating piston-to-head clearance, and I was unable to find a record of the thickness of common head gaskets, either here or on fordgarage.com. I wrote to Best about the gasket I'm using and they wrote back, so I thought I would start a thread and maybe folks can add information if they have it.
Per Best Gasket, the compressed thickness of the 509G (GraphTite) gasket is .054" +/-.002.
Old 12-30-2020, 12:12 PM   #2
Jack Shaft
Default Re: Compressed head gasket thickness, for the record
I've found copper clad gaskets to run as high as .070 crushed.
Jack Shaft is offline   Reply With Quote
Old 12-30-2020, 01:32 PM   #3
Jim Brierley
It varies depending on the brand and material. One site I checked said 16.877cc's @ .050" and 20.253 @ .060, another 17.474, I use 20cc and figure that is close enough.
Jim Brierley is offline   Reply With Quote
Old 12-30-2020, 01:44 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Jim is correct.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-30-2020, 01:48 PM   #5
alexiskai
alexiskai's Avatar
Thanks, well if you have any specific info from a vendor on a specific brand and material, please add it here.
