01-15-2021, 10:50 AM | #1 |
Water pump questions
Hi folks,
I'm going through everything on my '31, and have a question about the water pump. The pump is new, has a stainless steel shaft and I just packed it about 30 miles ago. It doesn't leak, but the shaft turns with a lot of resistance (with no belt) relative to a modern water pump. I coated the packing with silicon grease and that helped, but it is still fairly tight even though I haven't over-torqued the packing nut. Should the shaft have such resistance with the packing system? Also, the pump has a lot of end play...which seems odd - is that normal? I'm wondering if a leakless pump might be better. Tom |
01-15-2021, 11:37 AM | #2 |
Re: Water pump questions
I prefer leakless, but the originals rebuilt are great too!
www.whidbeymodelaclub.com |
01-15-2021, 12:50 PM | #3 |
End play could be due to wear in the head where the shaft rides. I replaced my packing with leakless seal. You cant see it behind the packing nut and it hasnt leaked a drop in 4 years. Be careful not to overtighten
01-15-2021, 01:27 PM | #4 |
Run it a while and see if it loosens up a bit. You should be good with that new packing for many years.
01-15-2021, 01:45 PM | #5 |
That's been my experience, it feels tight when it hasn't been turned for awhile. If you bolt the fan on and spin the fan blade by hand for a minute or so, it loosens up (again, my experience).
01-15-2021, 03:23 PM | #6 |
01-15-2021, 03:37 PM | #7 |
If your water pump is rebuilt like an original, the packing nut should only be tightened enough to stop the water from leaking,
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
01-15-2021, 03:42 PM | #8 |
Thanks all,
Lots of good feedback. I'll put some more miles on it once I get the engine back together, and see if it loosens up some. If not, I'll go leakless. |
01-15-2021, 04:16 PM | #9 |
This is what my water pump looks like. Any suggestions as to what kind it is? It looks nothing like others I have seen. Seems to work fine though. I have been told it's an industrial pump or one from a tractor
[ATTACH]452939[[ATTACH] |
01-15-2021, 07:44 PM | #10 |
You could build up a little brass on the end of the shaft to take up for wear on the head to eliminate the end play or add a little set collar. My old pump had the set collar on it so I re-used it when I rebuilt it.
