Old 10-26-2020, 07:17 PM   #1
melisahe
melisahe's Avatar
Default 49 Ford F1 project. What am I getting into?
Bought a rusted out F1, good frame and title. Got it down to frame cleaned primed painted. brakes done. Putting it back together, have a rebuilt 6 cyl flathead with a S10 trans mounted to it. It's a four speed T5. Nomenclature may be wrong. It is a four speed and it is mounted to the engine. The trans is much longer than original. Is there a blog on what must be done to make this work. The clutch seems to be reversed and it looks like a new cross member. All help deeply appreciated. Mike
melisahe is offline   Reply With Quote
Old 10-26-2020, 08:49 PM   #2
alanwoodieman
Default Re: 49 Ford F1 project. What am I getting into?
pictures? trans/cross member would be helpful. just finished a 49 F1-rust in cab corners/floor and in front and rear fenders-a lot of rust repair or buy new fenders
alanwoodieman is online now   Reply With Quote
Old 10-26-2020, 09:10 PM   #3
flatford8
flatford8's Avatar
What do you mean by “the clutch seems to be reversed”? ....I learned from Dick (V8 Coopman), that a 4-speed resembling a T-5 is actually a T-4, possibly from a diesel pickup. There’s no big bulge on the front right of the tail shaft where the OD gear would be. You’ll have to check the location of the shifter, if it will work in the cab. Some pics of the cross-member and the clutch would be good......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 10-27-2020, 03:03 AM   #4
Clem Clement
Clem Clement's Avatar
Does Van Pelt know later trannys?
Clem Clement is offline   Reply With Quote
Old 10-27-2020, 04:54 AM   #5
Mart
Mart's Avatar
If the trans is a 4 speed version of the T5 wouldn't it be worth swapping in a 5 speed version?
You will have to rephrase your comment re the clutch being reversed. We don't know what you mean or are asking.
Most transmission swaps require a custom driveshaft. This often requires cutting and welding. Normally there are places set up to do this work.
Mart.
Old 10-27-2020, 08:31 AM   #6
melisahe
melisahe's Avatar
clutch reversed-the clutch does not disengage when petal is pushed in. The reverse happens, to get the clutch to disengage (if hooked up) I would have to pull the petal out. Are there any links to what is involved? I purchased this as an assembly already together over a year ago and it may be five speed.
Old 10-27-2020, 08:38 AM   #7
Tim Ayers
If that is the case, I would go over everything for it seems like someone didn't know what they were doing.
Old 10-27-2020, 10:14 AM   #8
JSeery
JSeery's Avatar
Think some photos here might help straighten out what you have and how it is setup.
Old 10-27-2020, 10:44 AM   #9
GB SISSON
GB SISSON's Avatar
Look into a wilwood 'pull type' slave cylinder. I just installed one on a diesel conversion and it solved a lot of problems.
'47 1/2 ton pickup next project, '47 one ton panel 99% stock nearing completion, '47 2 ton with 8ba and 9' script stakebed, '46 1/2 ton woodie project,'59 F350 9' flareside pickup with cummins 6at. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 10-27-2020, 10:49 AM   #10
FortyNiner
FortyNiner's Avatar
Yup. Remove engine and trans. If the clutch plate is facing the wrong way it could cause the problem described. Checking the motor mounts and drive shaft fit would be wise.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is online now   Reply With Quote
Old 10-27-2020, 10:55 AM   #11
Bob C
The clutch should work the same as with the original trans.
Old 10-27-2020, 11:52 AM   #12
tubman
tubman's Avatar
After the clutch, I wouldn't trust a thing that was done so far.
Time to start from scratch.
Thread Tools
Display Modes
