04-18-2020, 04:21 PM | #1 |
Original BOYCO canister
Hello everyone,
I caught an original zinc galvanized BOYCO canister in the bay, which is intended for the running board on our roadster. When cleaning with a machine brush, I discovered that the twist lock is made of brass. Is that a peculiarity? If so, does this roughly indicate the manufacturing period? Thanks to all in advance for every hint!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
04-19-2020, 09:45 AM | #2 |
Re: Original BOYCO canister
I will have to check on mine when I get home but I think it was probably coated with tin to withstand water, oil, petrol. It probably would have been painted or had a decal on it.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
04-19-2020, 11:20 AM | #3 |
You need the other two for a set they came in 3, oil, water and gas and were painted white for oil, blue for water and red for gas. I think they were for the earlier Model T days.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
04-19-2020, 04:08 PM | #4 |
Guten Abend,
I have now worked up the container and will fix it with leather straps. I will leave the brass lid bare.
04-19-2020, 04:28 PM | #5 |
last
04-19-2020, 06:49 PM | #6 |
Mike
04-20-2020, 03:34 PM | #7 |
Hi Mike,
I received the information that 'blue' is not oil but water, a little bit too late. And therefore I changed the lettering tonight. Template for the "Boyco" label is available in Australia https://www.ebay.de/itm/Vintage-Boyc...s-Model-T-Chev / 233161593260? Hash = item36498391ac: g: WzsAAOSwcxVayyxq
04-20-2020, 09:51 PM | #8 |
Here is a set of original containers with their original running board bracket:
Brad in Maryland, USA |
