Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 06-04-2023, 12:31 PM   #1
lo c dan
lo c dan's Avatar
Default Model T coupe Q
How do you remove the lower panel below the trunk lid? My panel was so rusted I had to cut the panel apart to work with. . Now what's left is a small piece that looks to be tucked around and behind a frame flange. Is the an easy solution? Thanks.
" You haven't lived until you've almost died.For those who have fought for it, life has a meaning the protected will never know. "
lo c dan is offline   Reply With Quote
Old 06-05-2023, 12:13 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Model T coupe Q
You need to post on the Model T forum, not here. This section is not for car questions.
