Old 09-05-2021, 02:46 PM   #1
Al 29Tudor
Al 29Tudor's Avatar
Default Coup rumble lid
The rumble seat panel on my friends coupe looks like if it is closed it will bind against the lower panel and not open again.
Can anyone give me advice on this issue ?
Are there adjustments to the pivot points for allignment ?
Thank you for any advice you can offer.
Al
Al 29Tudor is offline   Reply With Quote
Old 09-05-2021, 03:44 PM   #2
wrndln
Default Re: Coup rumble lid
If the lower panel is a repro, they are formed incorrectly (not enough curve). If the panel is a repro, an original stiffener is needed inside the panel - don't ask me how I know this.
Old 09-06-2021, 09:40 AM   #3
Al 29Tudor
Al 29Tudor's Avatar
Wrndln,
Great information. What you discribed is just what it looks like on this car.
How is the original stiffener fastened to the lower panel?
Thank you again,
Al Leach
Old 09-06-2021, 11:02 AM   #4
Bob C
Check out these two links to Vince's site.
http://www.fordgarage.com/pages/trunkconstruction.htm
http://www.fordgarage.com/pages/trunkpanel.htm
Old 09-06-2021, 12:49 PM   #5
Al 29Tudor
Al 29Tudor's Avatar
Thank you Bob.
I hope to get to the car today with this new information.
Al
Old 09-06-2021, 01:10 PM   #6
wrndln
Default Re: Coupe rumble lid
Al,
Is your coupe a 28 or 29? The the top of horizontal part of the stiffener slides between the top of the sheetmetal panel where it is folded over and the lower part is riveted or screwed to the rear body crossmember. The folded over flange on the top of the sheetmetal panel is difficult to open slightly to insert the stiffener. I am attaching a picture of what appears to be a nice original stiffener on eBay. You need the vertical part of the stiffener assembly if you plan to have a rear mounted spare tire. The link to the stiffener is below.
BTW, on original panels the lower sheetmental panel is a different height on the ends than the middle. I can't remember if the repro panel had the same dimensions as the original panel. I can measure the original panel on my 28 coupe if you email me: [email protected]. I went through what you are trying to do some years ago. I ended up finding and installing an original panel with the stiffener with it in it. It fit like a glove, like all original parts do.
Rusty Nelson
https://www.ebay.com/itm/12479599631...kAAOSwuXdg30XG
Old 09-06-2021, 02:06 PM   #7
Al 29Tudor
Al 29Tudor's Avatar
Wrndln,
Thank you foe all the information.
The car I'm working on is a 1928 with a rear mounted spare tire and has a fantastic paint job.
It belongs to my friend.
Al
Old 09-10-2021, 09:45 AM   #8
Al 29Tudor
Al 29Tudor's Avatar
Wrndln, You are exactly on target with lower panel issue. I had a chance to view a photo album and on the second page it showed the bottom panel missing. I'll email you and if you get a chance maybe take some measurements.
Thanks so much.
Al
