Old 10-06-2023, 07:03 AM   #1
[email protected]
joe.manfre@me.com's Avatar
Default Fuel Filter issue
I recently installed an in line fuel filter(the car never had one). After running for about 20 minutes the car stalled and ran the fuel filter dry. I tried releasing the gas cap thinking it was a vapor lock, no change.
I have an external fuel valve under the hood, before the filter, making it easier to service the filter.
During this stall out, I remove the fuel line after the filter, open the valve, no fuel comes out. Then I open the fuel line before the filter and fuel flowed easily.
I changed the filter, thinking I got a defective one. Ran the car for 20 minuted or so, same problem.
I have eliminated the filter and will test drive today. Any suggestions?
joe.manfre@me.com is offline   Reply With Quote
Old 10-06-2023, 07:10 AM   #2
nkaminar
nkaminar's Avatar
Default Re: Fuel Filter issue
In inline fuel filters do not work well with gravity feed unless they are designed for gravity feed.
Old 10-06-2023, 08:06 AM   #3
Patrick L.
Patrick L.'s Avatar
Once the air is bled from the filter it should flow as long as its set correctly.
Old 10-06-2023, 09:11 AM   #4
LeonardS
I had the same problem. Fuel would not gravity feed through an in-line Napa filter, but the old one would flow fuel just fine. I just removed the inline filter.
LeonardS is offline   Reply With Quote
Old 10-06-2023, 09:40 AM   #5
David in San Antonio
David in San Antonio's Avatar
Does anyone know of a low-restriction inline filter that will work ?
1930 ('31?) Deluxe "Wretched Roadster"
Restored 1957
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 10-06-2023, 09:52 AM   #6
old31
I have been using NAPA 3002 on gravity fed systems for years with no problems.
old31 is offline   Reply With Quote
Old 10-06-2023, 10:04 AM   #7
[email protected]
Just had the car out for a 45 minute drive, no filter, no issues.
She doesn't like a gas filter....
Old 10-06-2023, 10:05 AM   #8
Old31 - Part number and retail source! Thanks!
Restored 1957
Alamo A’s Club
Old 10-06-2023, 11:37 AM   #9
JOES31
JOES31's Avatar
Go to a hardware store or lawnmower shop and buy the in line
filter for a 8 to 16 hp motor. They are small, but will allow gas to drop down
to the carb. I have run one on mine for 12 years. Clean gas is more important than you think. The ones I'm talking about are sometimes clear plastic or opaque so you can
actually see the gas flowing.
JOES31 is offline   Reply With Quote
Old 10-06-2023, 12:14 PM   #10
Bob from Northport
Bob from Northport's Avatar
How about checking the filter inside the gas tank???
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 10-06-2023, 12:36 PM   #11
CarlG
CarlG's Avatar
I use one of these:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-06-2023, 12:53 PM   #12
[email protected]
Has anyone used a Bowl Filter?
https://www.brattons.com/OUT-OF-STOC...uctinfo/13051/
Old 10-06-2023, 12:54 PM   #13
[email protected]
Regarding the image Carl G posted.
Where is that available? Part number?
Old 10-06-2023, 01:22 PM   #14
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by [email protected] View Post
I use a WIX 33039 in my glass sediment bowl. https://www.oreillyauto.com/detail/c...ter/wix0/33039
Old 10-06-2023, 02:05 PM   #15
Sunnybrook Farm
Sunnybrook Farm's Avatar
I had the same problem and it ran fine after removing fuel filter. Cast iron sediment bowl so I will get one for a tractor if I put a filter back on.
Sunnybrook Farm is offline   Reply With Quote
Old 10-06-2023, 02:06 PM   #16
old31
https://www.napaonline.com/en/p/FIL3002
Old 10-06-2023, 02:42 PM   #17
johnneilson
Many years ago had a problem with water in fuel making the paper element swell up enough to not allow fuel to flow.
Also had fuel with enough water in it to be nonflammable gas.
Try a filter with plastic or sintered metal element
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 10-06-2023, 03:02 PM   #18
[email protected]
modela@aol.com's Avatar
I have been using these WIX filters in my glass sediment bulbs on my cars for years and have been very happy with them.. Never had issues with any fuel starvation and I change them every few years as preventive maintenance. Like everything else their price have certainly gone up over the years..
Also I typically add a pill sized super magnet to the metal bottom of the WIX filter. It is amazing the amount of rust particles that these magnets attract keeping the fuel to the carb super clean....
modela@aol.com is offline   Reply With Quote
Old 10-06-2023, 05:38 PM   #19
Herb Concord Ca
I have used a small filter that was just on the VW Bettle.
Herb Concord Ca is offline   Reply With Quote
Old 10-06-2023, 06:21 PM   #20
SDJason
SDJason's Avatar
Same here
SDJason is offline   Reply With Quote
