Old 07-17-2017, 02:57 PM   #1
Bonniewwyn
Default '31 Vicky Right Door Glass Channel
Does anyone know what the correct length of the glass channel is?? I have 3 pcs all quite different and none seem to work correctly. They are marked Vintique on all of them. Also distance from the right regulator arm slot at its end to end of the channel would be a big help!
Bonniewwyn is offline   Reply With Quote
Old 07-18-2017, 06:41 AM   #2
art ebeling
art ebeling's Avatar
Default Re: '31 Vicky Right Door Glass Channel
Is this what you need?
art ebeling is offline   Reply With Quote
Old 07-18-2017, 12:13 PM   #3
Bob Bidonde
Bob Bidonde's Avatar
The Channels for both doors are the same.
File Type: pdf 190A Window Glass Channel Positioning - Copy.pdf (216.6 KB, 37 views)
Bob Bidonde
Old 07-18-2017, 12:39 PM   #4
Bonniewwyn
THat was exactly what I needed. Big Thank u !!
Old 07-18-2017, 12:47 PM   #5
Oldbluoval
Oldbluoval's Avatar
Left and right channels are mirror-image of each other. Left and right are different in slot turn-ins.
Old 07-18-2017, 01:04 PM   #6
jw hash
jw hash's Avatar
oldbluoval is correct, a watch out if you go reproduction channels a lot of them are made wrong. they will work but you have to grind them down. they also use a special rubber for setting the glass
jw hash is offline   Reply With Quote
Old 07-19-2017, 10:13 AM   #7
Bob Bidonde
Which way do the slots turn=in, outward or inward?
Bob Bidonde
Old 07-19-2017, 12:47 PM   #8
jw hash
jw hash's Avatar
the smooth side inward. the fold over goes towards the out side.
Old 07-20-2017, 10:24 AM   #9
Bob Bidonde
Thanks JW.
Bob Bidonde
