Old 07-27-2016, 08:06 AM   #1
Killerbee
Default Down draft problems
I recently put a downdraft with a freshly rebuilt Holley 94 on my banger engine. I'm having issues with it idling and also loading down and backfiring. It backfires out of the carb and the exhaust. This all points to an vacuum leak to me. I've checked everywhere it could be leaking sprayed started fluid over the base and where it meets up with the block with no difference in idle. If i half choke it it will idle and will not pop or backfire. Once again pointing to a vacuum leak. Not sure what I'm missing here. All vacuum ports are plugged on the carb. Is it possible the intake is warped and not meeting up to the block flush.
Killerbee is offline   Reply With Quote
Old 07-27-2016, 08:18 AM   #2
CA Victoria
CA Victoria's Avatar
Default Re: Down draft problems
What size jetting was the carb set up with?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 07-27-2016, 08:28 AM   #3
Killerbee
51 jets
Old 07-27-2016, 10:50 AM   #4
CarlG
CarlG's Avatar
If you are not using a fuel pump, that is most likely your problem. I have run both a Weber and a Stromberg 97 with and without a fuel pump. They both ran much better with a fuel pump. When running without a fuel pump, symptoms were pretty much like you described, but only some of the time.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-27-2016, 11:07 AM   #5
PC/SR
Probably not an air leak, just running lean, but you have to eliminate the possibility first. The 51 jet should be OK, but try a 52 just to see. Carefully adjust the idle screws because they run on the idle circuit longer than stock because they were designed for bigger engines. Idle adjustment is very sensitive. The idle hole size in the throttle body can make a difference at idle and running at low speed, there are two different sizes. Mine worked better with the smaller size. Try the accellerator pump link on the longest throw, the winter setting, and see what happens on acceleration. They do tend to run lean at low speeds. Tuning the Holleys is much more art than science, but they do work nice when set up. What's your cam?
PC/SR is offline   Reply With Quote
Old 07-27-2016, 11:26 AM   #6
Killerbee
Stock cam. I'm getting plenty of fuel to the carb as it sits lower than the tank. There's no difference where the accelerator is set it was about the same in all three holes. I am running the stock distributor. Could it be a timing issue.? Maybe I'm not getting enough advance?
Old 07-27-2016, 11:30 AM   #7
Killerbee
https://youtu.be/qgAcCQcdjv8
Old 07-27-2016, 01:24 PM   #8
emf
emf's Avatar
I also thought that the carb sitting lower than the tank would be OK. Granted, I'm running two carbs, but the pump made a great deal of difference. I see in your video that you did not spray around the junction of the block and manifolds... Just a thought.
Frank
emf is offline   Reply With Quote
Old 07-27-2016, 01:48 PM   #9
midgetracer
midgetracer's Avatar
I agree with Carl and EMF. I fought with one on a 31 tudor that belonged to a friend of mine. He insisted a fuel pump was not necessary. He had a single Stromberg 97 (new). I tried everything and finally convinced him to put on a fuel pump regulated to 2 psi and it is the best running A I have ever worked with. Try a fuel pump.
midgetracer is offline   Reply With Quote
Old 07-27-2016, 02:25 PM   #10
1931 flamingo
1931 flamingo's Avatar
If you've backfired thru the carb the PV may be bad. Don't most run an 81 carb??
Paul in CT
Old 07-27-2016, 04:19 PM   #11
Dave in MN
Dave in MN's Avatar
I recently set up two overhead valve engines with down-draft single carb and dual carbs. We were looking for the maximum power we could get from the combinations. Not until I added the rotary fuel pump and a regulator did I have success jetting them to idle and perform at full load on the dyno. So, I agree with the gents above who suspect you need a fuel pump. One of them was a new Stromberg 97, I will go back and check my records as to the best main jet for the 97.
Good Day!
Dave in MN is offline   Reply With Quote
Old 07-27-2016, 04:59 PM   #12
CarlG
CarlG's Avatar
Originally Posted by Killerbee View Post
...I'm getting plenty of fuel to the carb as it sits lower than the tank...
That's what I thought as well. I am using a single 97 carb and had a little over 6" drop from the bottom of the tank. However, even with more than half a tank of gas, it wasn't enough head pressure to keep things percolating like it should. Added the fuel pump and a regulator set at 2.5# and problem solved.
Alaskan A's
Old 07-27-2016, 05:14 PM   #13
Lawrie
Lawrie's Avatar
you can make the 97 run great on the gravity feed,you just have to modify the needle valve,mine has been trouble free for thousands of miles
Lawrie is offline   Reply With Quote
Old 07-27-2016, 07:45 PM   #14
glenn in camino
glenn in camino's Avatar
I'm running a Webber on one of my As. works really good.
glenn in camino is offline   Reply With Quote
Old 07-28-2016, 04:46 AM   #15
colin1928
colin1928's Avatar
Bad holley power valve will do as described
colin1928 is offline   Reply With Quote
Old 07-28-2016, 06:28 AM   #16
1929
I had a similar problem with the 97 Stromberg. I bought a fuel pump and a regulator, but I didn't install it yet because I think the jet size change from 45 to 43 has it running much better.
1929 is offline   Reply With Quote
Old 07-28-2016, 06:30 AM   #17
1929
51 jets
how do the spark plugs look? did you check them yet?
Old 07-28-2016, 07:16 AM   #18
cw253748
cw253748's Avatar
Carb is too lean. For one check to see if you have fuel squirting out with the engine off in the carb from the accelerator pump. I think you need to tear the carb apart again.
cw253748 is offline   Reply With Quote
Old 07-28-2016, 08:55 AM   #19
Bob Bidonde
Bob Bidonde's Avatar
I had this problem and it was caused by vacuum leaks inside of the carburetor. In my case, the gaskets were not properly in place.
Bob Bidonde
Old 07-28-2016, 09:11 AM   #20
Killerbee
I'm getting plenty of fuel out of the discharge nozel. I haven't pulled the plugs. I haven't been able to drive it with this carb. I'm thinking power valve or just tired old carb. Might just buy a new carb with what I'm seeing about old tired Holleys they can be finicky.
