11-13-2014, 10:20 PM | #1 |
'50 Ford Passenger Side Mirror
I've been wanting to install a passenger side mirror for a while. I want it to be functional and not just for looks. I'm planning on getting the OEM type for '50 models. Does anyone have and use one, also how well do they function? Exact measurements for the mounting location would also be a big help. Thanks
Gene |
11-14-2014, 07:28 AM | #2 |
Re: '50 Ford Passenger Side Mirror
I got a set of mirrors for my '50 from 2 different vendors and they were all the same. You can't adjust the right mirror to where you can see in it proper and then it won't stay in place. It has been a while and they may have corrected the problem. A template comes with the mirrors. There are 2 mounting options and I mounted mine below the crease in the door. The other option is up above the crease in front of the vent window. It might work better in that location.
11-14-2014, 09:40 AM | #3 |
The mirrors that are being sold by Carpenter at about $50. will work on either side and look like the original mirror. I have the temp. drawing for the mirror. If you e-mail me with your address I will scan it and send it to you.
JT |
11-14-2014, 07:09 PM | #4 |
Hydroe-electric on line. Comes with a template. Not sure on passenger side...Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
11-16-2014, 07:45 PM | #5 |
Also, I mounted mine on the vertical part of the door just in front of the vent window.
Butch In a world filled with stress it is better to give than to receive. |
