Old 03-18-2017, 09:05 AM   #21
larrys40
Default Re: cam replacement
Originally Posted by harryc View Post
remove the cam, reinstall new with timing gear of your choice and make sure all is aligned. adjust all lifters to desired clearance. You can use the service bulletins rule of 9 I believe in the stock Model A bulletins.
I removed a HP cam and went back to a stock touring cam.
Larry Shepard
Larry -did you have any problem getting the keepers back on the valves[/QUOTE]
Harry, no problem getting keepers back on. If you are using the two piece style I use a little bit of grease to help hold them to the stem while I'm using the valve/spring compressor to release. Just take your time and careful and I'm sure all will go well. Worst case you have to pull something but I think you should be fine.
Larry
larrys40 is offline   Reply With Quote
Old 03-18-2017, 09:10 AM   #22
Mitch//pa
Follow Larry's great advice on this thread and you'll be fine
Old 03-18-2017, 06:55 PM   #23
colin1928
colin1928's Avatar
Larry s method works well and I have used it with original style valves and keepers
But if you have modern style valves and keepers it is easier to remove the head
colin1928 is offline   Reply With Quote
