Old 02-05-2013, 03:06 PM   #1
BarracudaBoy
Default Stirring the "When to change oil" pot
I'll just leave this here....
http://www.edmunds.com/car-care/stop...762858&msite=w
BarracudaBoy is offline   Reply With Quote
Old 02-05-2013, 04:18 PM   #2
MikeK
MikeK's Avatar
Default Re: Stirring the "When to change oil" pot
When my hour meter reaches ______
MikeK is offline   Reply With Quote
Old 02-05-2013, 04:32 PM   #3
miss victoria
I have steering mast holders for the tiny tach. $35.00 + $5.80 usps.
miss victoria is offline   Reply With Quote
Old 02-05-2013, 04:36 PM   #4
hardtimes
hardtimes's Avatar
Originally Posted by BarracudaBoy View Post
When oil prices......go down !
hardtimes is offline   Reply With Quote
Old 02-05-2013, 04:57 PM   #5
Bruce Adams
Bruce Adams's Avatar
And your point is???
parrticularly among Model A owners with no oil filters and many using non-detergent oil.
Bruce Adams is offline   Reply With Quote
Old 02-05-2013, 05:51 PM   #6
1937pickup
I quit the 3K oil change long ago on our grocery getters.
1937pickup is offline   Reply With Quote
Old 02-05-2013, 07:35 PM   #7
Louis
I change oil in my 31 coupe when the oil turns black, some times at 300 miles, some times at 450, on my newer cars I change it at around 6ooo-7000 miles, aprox. twice a year, you gotta give your 80 year old car a little TLC.
I've suffered a great many Catastrophe's in my life.....most of them never Happened.
Louis is offline   Reply With Quote
Old 02-05-2013, 09:04 PM   #8
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I have 2 Model A's, The coupes oil gets changed at around 1000 miles and the roadster between 300 to 500. they both have rebuilt engines with around 8000 miles. For some reason the Roadsters oil gets dirty early so it gets changed. I always use 15/40 Carquest.
Barry B./ Ma. is offline   Reply With Quote
Old 02-05-2013, 10:48 PM   #9
columbiA
I change the oil on both my A,s every 1,000 miles-no filter.The oil still looks clean on dip stick,but I would rather not wait until oil looks dirty before changing.I know I could go longer between changes,but I have also been able to drive over 75,000 miles on a used engine that had many miles on it before I got it & it was still running good when I sold the car.If looked after & driven sensibly,babbit will last a long time.
columbiA is offline   Reply With Quote
Old 02-06-2013, 02:52 AM   #10
wensum
wensum's Avatar
I restored a Model A in 1966 and did a considerable mileage in it, much of it at relatively high speeds 50-60mph.
I don't recall changing the oil, just topping it up and then we used re-refined oil which was basically discarded oil from garages and fleets that was refined again.
Never any problems with bearings etc. And when you strip down an old motor and see the extent of the sludge, it's amazing that they kept running
wensum is offline   Reply With Quote
Old 02-06-2013, 08:18 AM   #11
gweilbaker
gweilbaker's Avatar
My oil is in a constant state of change, leak a quart, add a quart.
gweilbaker is offline   Reply With Quote
Old 02-06-2013, 09:42 AM   #12
Randy in Illinois
Randy in Illinois's Avatar
Once a year. rather it needs it or not. non-detergent 40w better oils now days than back then.
Randy in Illinois is offline   Reply With Quote
Old 02-06-2013, 09:48 AM   #13
mhsprecher
mhsprecher's Avatar
This is a good link and relevant to our modern cars. On Model A's with no filter and without the modern tolerances, I am not so sure. I didn't see anything about length of time. It used to be 6 months or X,000 miles. Has that changed, too?
mhsprecher is offline   Reply With Quote
Old 02-06-2013, 09:50 AM   #14
mhsprecher
mhsprecher's Avatar
It may make sense to get an oil analysis, too, depending upon the cost. Has anyone done this?
Old 02-06-2013, 10:00 AM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
My guess is an oil change would be cheaper.
Old 02-06-2013, 10:32 AM   #16
Ross/Kzoo
Ross/Kzoo's Avatar
My BIL did tha twith his farm machinery. As an ex-Navy mechanic he did it religiously and and found that his JD had metal fragments in the oil. Couldn't do anything about the bearings until afeter the harvest. It didn't last that long.
Ross/Kzoo is offline   Reply With Quote
Old 02-06-2013, 08:35 PM   #17
Old182
Old182's Avatar
I agree with Tom. Don Garlits once said that cranks are cheaper than engines, bearings are cheaper than cranks, and oil's cheaper than bearings. Sooo, just change the oil. Modern oils are infinitely better than what Henry had (excluding non-detergents of course; they should never be used) with antioxidants, corrosion inhibitors, detergent/dispersants, blah, blah. If your oil's turning dark it means the dispersants are doing their job of keeping crap (particles of combustion, etc.) in suspension so they can be drained. It's probably best to change the oil at the end of the touring season just before storage so that your crankcase has fresh additives in it. That way, if you start the engine during storage for short periods, say to charge the battery, the water and fuel dilution that will find its way into the oil can be neutralized. With year-old oil, additives will be depleted and may not do the good things they should. $0.02.
Old182 is offline   Reply With Quote
