Old 02-04-2020, 03:37 PM   #1
Russ/40
Russ/40's Avatar
Default Points Cam ?
Can someone tell me how to identify a "A" points cam from a "B" points cam?
I think the ramp opens the points more quickly with the "B" cam. The "A" cam seems to open and close at about the same rate. I think that is what I'm seeing.....very hard to tell.
Someone add to, or confirm?
Thank you
Russ/40 is offline   Reply With Quote
Old 02-04-2020, 04:43 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Points Cam ?
Both sides of the ramp look the same on A cam, one side taperes off on the B cam
Old 02-04-2020, 07:47 PM   #3
Russ/40
Russ/40's Avatar
Thank you Kurt. I guess I was seeing that as well. Nice to have a confirmation. The "B" points almost snap open.
Old 02-04-2020, 11:17 PM   #4
Gary WA
Gary WA's Avatar
This Help Thanks to supplier of photo.
www.whidbeymodelaclub.com
Old 02-05-2020, 12:24 AM   #5
J Franklin
J Franklin's Avatar
The B cam allows better coil saturation I have been told, and is the profile sold now.
Old 02-05-2020, 12:37 AM   #6
Russ/40
Russ/40's Avatar
Photo does not show well enough to tell
Old 02-05-2020, 01:55 AM   #7
Dan Partain
Dan Partain's Avatar
How about this?
Dan Partain is offline   Reply With Quote
Old 02-05-2020, 11:22 AM   #8
Russ/40
Russ/40's Avatar
Thank you Dan
Old 02-05-2020, 11:25 AM   #9
ryanheacox
ryanheacox's Avatar
Interesting that they kept the A cam available after the B cam was introduced.
ryanheacox is offline   Reply With Quote
