Old 05-24-2013, 05:49 PM   #1
d.
Default ??? how to get junk tire off the rim
OK guys...I have several pretty good rims that have old split, junk tires on them. What are some ideas to cut the tire off and save the rim? I tried just prying it off, but that isn't working.
thanks for your input.
d. is offline   Reply With Quote
Old 05-24-2013, 05:53 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: ??? how to get junk tire off the rim
Rather crude, but Chief would pile up loose hay, put the wheels on top & BURNED them off!! Stripped the paint ALSO!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-24-2013, 06:01 PM   #3
Roadster62
Roadster62's Avatar
Saws-All, or a Skil saw but don't catch the rim. Once you get a portion the sidewall removed you can pry the steel enforced bead off. Bolt cutters work well at this point. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 05-24-2013, 06:22 PM   #4
ronn
agreed with 62-sawzall is fast and furious!
Bill needs to put the fire dept on standby....
Old 05-24-2013, 07:10 PM   #5
1crosscut
1crosscut's Avatar
Here is a link to the AA Truck site that I posted some pictures and information on how I removed old tires from my truck rims. They are tires with retainer rings but perhaps it will help.
http://forums.aa-fords.com/viewtopic.php?f=1&t=3995
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-24-2013, 08:28 PM   #6
Pete
Pete's Avatar
Take them to a tire shop??????
They can have them off in about 30 seconds.
Old 05-24-2013, 10:02 PM   #7
al's28/33
al's28/33's Avatar
The modern hydraulic/pneumatic thing-a-ma-jigger that takes modern tires off modern rims will tear up your 85 year old rim, don't do it.
Try some ELBOW GREASE and let us know what happens!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 05-24-2013, 10:54 PM   #8
700rpm
700rpm's Avatar
Blood, sweat, and tears.
Ray Horton, Portland, OR
Old 05-24-2013, 10:57 PM   #9
Pete
Pete's Avatar
The tire shop I go to is a nationwide chain and they can handle it.
They have machines for old stuff.
Old 05-24-2013, 11:44 PM   #10
marks1929tudor
Not sure exactly what problem you are having , never really had any trouble taking old tires off of wheels, just let my twelve year old dismount a few I had here, he had fun learning cars where much easier to work on than today's cars . I told him don't expect to change a tire on a modern car like this lol!!!!
marks1929tudor is offline   Reply With Quote
Old 05-25-2013, 12:19 AM   #11
Rowdy
For most tires I can dismount them myself. For dried out hard tires that I can not break the bead I take them to the tire shop. $8 to dismount and $2 for tire disposal and I don't have to worry about disposing of it myself. The local tire stores will not dispose of any tires they did not dismount, so one less hassle later or having to wait for the county to have a free tire disposal day. Rod
Rowdy is offline   Reply With Quote
Old 05-25-2013, 12:51 AM   #12
31 A4door
I have cut tires off with a grinder a few times. It gets smokey a little but you can cut through the wire easily.
31 A4door is offline   Reply With Quote
Old 05-25-2013, 01:58 AM   #13
dumb person
dumb person's Avatar
"Back in the old days" i would demount tires by over-inflating them until they burst. Seems like a bad idea with car tires though.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 05-25-2013, 02:08 AM   #14
Mitch//pa
with my new machine i can dismount the tire in seconds without touching the rim, it even has a side lift to pick it up....
Old 05-25-2013, 02:51 AM   #15
ba49
I use a razor knife and slice through the sidewall and then they come right off. BE CAREFUL though, they don't call them a razor knife for nothing.
ba49 is offline   Reply With Quote
Old 05-25-2013, 09:17 AM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
Don't burn them off as I'm sure the heat will be very bad for spoke tension.
I've used a knife to cut the bulk of the tire off, then the bead can be hammered down with a chisel. Once the bead is down it can easily be peeled off or cut.
I've also used a very sharp chisel to cut the bead while it's still in place, after I cut away the bulk of the tire.
What I just said isn't good though if you want to save the tube, wich I usually try to do. Harbor Fright sells a tire bead breaker for not too much money.
Old 05-25-2013, 09:26 AM   #17
machine girl
To pop the bead we back over the tire with our pickup.
machine girl is offline   Reply With Quote
Old 05-25-2013, 09:54 AM   #18
Roger V
Roger V's Avatar
Like machine girl, I have carefully driven over the tire without touching the wheel. I also have used a jack on the tire and under the pickup at a sturdy spot. For rock hard tires I've used a sawzall but not at the wire bead where a bolt cutter was safer. Nasty job at best..............
Roger V is offline   Reply With Quote
Old 05-25-2013, 10:55 AM   #19
eagle
eagle's Avatar
Soak the bead with some penetrating oil for a few days if its really rusted on. Then use a crow bar and a maul. Careful of your rim, if it gets "scarred" a bit use a die grinder to clean it up.
eagle is offline   Reply With Quote
Old 05-25-2013, 12:58 PM   #20
mantta
mantta's Avatar
Location: Keweenaw Bay, MI (Michigan's Upper Peninsula)
I use my gasoline powered wood splitter for breaking beads. It does an excellent job.
mantta is offline   Reply With Quote
Thread Tools
Display Modes
