Old 01-09-2021, 09:16 PM   #21
w.michael
w.michael's Avatar
Default Re: Shopping list for new A
You will need an adapter for the compression tester. Bratton's part # 8471. Snyder's part # A-12405-ADP.
W. Michael
w.michael is offline   Reply With Quote
Old 01-11-2021, 11:57 AM   #22
katy
katy's Avatar
Originally Posted by Blown Gasket View Post
This will do me several jobs and I would guess pull off the hub.
I have one like that and they work grrreat.
Old 01-11-2021, 05:13 PM   #23
Toytrk85
Be sure to make yourself a brake adjusting tool (I don't have the link off hand but has steps cut in to aid in brake adjustment and a couple continent type squeeze bottles to easily top off the transmission/differential, and steering box.
Toytrk85 is offline   Reply With Quote
Old 01-11-2021, 05:28 PM   #24
McMimmcs
McMimmcs's Avatar
Originally Posted by Jacksonlll View Post
Use a nice big sheet of cardboard and forget he creeper. Just a big box you can pitch when it gets dirty.
Common sense and money cents from an experienced veteran.
Old 01-12-2021, 02:07 AM   #25
redmodelt
redmodelt's Avatar
Never have liked creepers, I pull the wrench one way and the creeper goes the other. Easier to just lay on the floor and get in a position that is easy to work from, often that is not flat on my back. Cardboard or old carpet works for me. Sometimes I will put a couple of wood blocks under my head for neck support. If you get one of the original type hub pullers, wait till you get the car so you can see if ring, groove or both on the car. Sometimes it is a mix of both.
