12-03-2016, 07:33 PM | #1 |
%% back firing
Friends 55 all original lightly backfires when pushing again compression like when going down a hill..It is a 272 with standard tranny.so hope someone can maybe help..It is hard to explain but it seems to goThanks poof poof or maybe patch patch and is not really a loud backfire per say..
12-03-2016, 07:35 PM | #2 |
Re:55 back firing
Next time I will review my post ..Sorry Harry
12-03-2016, 07:58 PM | #3 |
Re: %% back firing
I would check the timing. It could also be that the muffler is wore out.
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
12-03-2016, 08:40 PM | #4 |
Re: %% back firing
Sit back and enjoy the sound
12-03-2016, 09:29 PM | #5 |
Re: %% back firing
My '57 Fairlane w/a 312 would do that when going down a big hill (when I took my foot off the gas ). I don't think its anything to worry about . - FF
12-04-2016, 09:37 AM | #6 |
Re: %% back firing
12-08-2016, 11:33 PM | #7 |
Re: %% back firing
Check the points. Mine makes a little more of a pop when the rubbing block is going away and they are not opening enough.
12-08-2016, 11:51 PM | #8 |
Re: %% back firing
when I first got my 51 merc, the tailpipes from the mufflers back were swiss cheese, and did the same thing, when I replaced the exhaust , no more problem. I think holes in the exhaust pipes caused the light backfiring.
12-09-2016, 10:50 PM | #9 |
Re: %% back firing
It's been way too many years since I've had the pleasure of driving and listening to a nice V8 pop out of the tailpipes.
When the carb throttle plates are closed at higher rpm the intake manifold vacuum goes high, pulling some (extra?) fuel thru the idle jets but with virtually no air in the resulting fuel/air mixture. Without enough air the mixture only partially ignites in the cylinder, then it passes out into the hot exhaust pipes where it usually finds a bit of extra oxygen and can re-ignite. As long as the engine is burning cleanly the rest of the time, enjoy the music. . Last edited by dmsfrr; 12-10-2016 at 01:18 PM. |
12-10-2016, 12:39 AM | #10 |
Re: %% back firing
Hi all,
I have a stock bodied 50 Ford coupe with a 302 so I don't really belong on any of the Fordbarn sites but the sound every one is describing is what I have also. That is the perfect sound as far as I am concerned. Love it!! |
12-10-2016, 12:16 PM | #11 |
Re: %% back firing
Anyone who finds this sound annoying is not a true gearhead!
12-10-2016, 01:23 PM | #12 |
Re: %% back firing
12-10-2016, 04:05 PM | #13 |
Re: %% back firing
Thanks dmsfrr..........I appreciate that!!
12-11-2016, 10:06 PM | #14 |
Re: %% back firing
man its still ford, you just made it go faster, so come on in and enjoy
12-11-2016, 10:13 PM | #15 |
Re: %% back firing
I had a 57 Studebaker silver hawk that did that, it was the fuel pump over powering the needle and seat on down hill engine on compression, flooded the carb and let the engine back fire, added a fuel pressure regulater and solved the problem
12-11-2016, 11:29 PM | #16 |
Re: %% back firing
Thanks WestCoast!! I will and I do...........
