Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 10-30-2020, 03:45 PM   #1
sofield
Default Used Model "A" Engine
City: Hauppauge
State: New York
Price: $1,075
I bought a used running engine sight unseen for a project car. The car owner changed his mind and decided on a rebuilt engine. After I received the engine prior to the customer changing his mind I did the following work. Removed the head, installed new studs, noticed pistons were .040 over and very little cylinder ridge, milled head, valve job, set valves int .012 ext .014, checked center main, new pilot bearing. Comes with clutch plate but no disc. I don’t have test bed to run the engine after completing. I will load engine for you. Will ship at extra cost.
sofield is offline   Reply With Quote
