09-30-2017, 11:47 AM | #1 |
Lifting an 8ba flathead
I am about the lift a fully outfitted 8ba. I am going to pull 4 corner intake bolts and use those lift points to secure my 4 chain adjustable lift tool plate with 4 grade 8 bolts. Thoughts on that before I do it?
JB |
09-30-2017, 11:55 AM | #2 |
Re: Lifting an 8ba flathead
Lifting it by the carb bolts isnīt an issue so for strenght it will work just fine.
09-30-2017, 02:51 PM | #3 | |
However, I've always been skeptical of lifting a complete, fully assembled, Flathead engine using (3) 5/16" carburator mounting studs/bolts, especially if they are mounted in an aluminum intake.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 10-01-2017 at 04:32 AM. |
09-30-2017, 03:40 PM | #4 |
We still use the "old school" method of a stout chain with end tabs placed under two head nuts. I made it over 60 years ago, and it has never dropped a fully assembled engine, even with the transmission attached.
09-30-2017, 03:45 PM | #5 |
Thanks guys, we were successful, the engine is in!
JB |
09-30-2017, 10:21 PM | #6 |
What year truck are you building? |
10-01-2017, 08:11 AM | #7 |
Could that be a 52 cab in the background?
10-01-2017, 09:06 AM | #8 |
10-02-2017, 06:52 AM | #9 |
No doubt I went overboard, I made a 1/2" plate, holes to match exhaust manifolds, removed my Reds Headers, welded 5/8" bars bent U shaped, using engine balancing lift working alone was perfect lift out of my engine run test stand complete with transmission, working alone I seem to take more care I guess, I didn't want to remove head bolts, intake bolts, water pump bolts etc., see pic
