Old 08-27-2017, 09:44 AM   #1
dave t
Default 1936 Ford mechanical brake information
Could anyone please tell me if the rear stock brake shoes should both move outward equally as the as the brake pedal is engaged ? Also who sell 1936 brake wedges?
thanks Dave T
dave t is offline   Reply With Quote
Old 08-27-2017, 11:58 AM   #2
Willit Stop
Willit Stop's Avatar
Default Re: 1936 Ford mechanical brake information
Yes. Equally. C&G Ford parts MIGHT sell them.As long as you're into the brakes you may want to install "floaters" or "energizers". I used them on my coupe and they work as well as juice brakes.Easy install too.
Willit Stop is offline   Reply With Quote
Old 08-27-2017, 02:23 PM   #3
Terry,OH
Terry,OH's Avatar
There are two different wedges for 36. If your brake pedal has the number 17 embossed on the arm inside the car you need 68-2050 which is the later style. Early style is the same as 35 Ford 48-2050 the 68- style results in a smoother brake.
Terry,OH is online now   Reply With Quote
Old 08-27-2017, 07:51 PM   #4
OLD AS I
OLD AS I's Avatar
willit stop, what are "floaters" or "energizers" that you refer to ?.
OLD AS I is offline   Reply With Quote
Old 08-28-2017, 07:40 AM   #5
Don Rogers
Don Rogers's Avatar
Floaters/energizers were aftermarket devices that replaced the fixed wedge adjuster in 1935/38 Fords. The energizers floated and allowed the upper part of the brake shoe to center on the hub, giving better braking. Here are some photos.
Don Rogers is offline   Reply With Quote
Old 08-28-2017, 09:51 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
Another posibility for mechanical brake equalizers/energizers/floaters are offered by a member here known as "flathead ted". Folks who have used these say they work well, and Ted has some videos of cars making panic stops, when using his floaters, on his website. I'll post pics of these if I can find them.
I haven't personally used Ted's floaters, but have used some of those posted above by Don Rogers, and they work very well in my avatar 35. In fact they work as well as the hydraulic brakes on some of the 39 - 48 Fords I have driven. JMO.
John
Old 08-28-2017, 10:05 AM   #7
Admiral
Admiral's Avatar
If you're looking for brake wedges, get in touch with Fred at Southside Obsolete out of Minnesota (http://www.southsideobsolete.com/Sou...e/Welcome.html). I bet he has NOS ones in stock.
Admiral is offline   Reply With Quote
Old 08-28-2017, 04:28 PM   #8
Floyd
Floaters work great. I have them on my 32 and it stops as good or better than my 40. The very best floater setup is from Flathead Ted. I can't imagine anyone wanting anything less than the best when it comes to brakes. Flathead Ted is the only way to go.
My opinion
Floyd is offline   Reply With Quote
Old 08-29-2017, 08:16 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
The wedge can float alot, one shoe can move before the other, but it should be almost the same unless some of the springs are weak, wrong, modified
later in 36 the factory came out with "floaters", much like the flathead ted ones, but no lock nut needed
both rollers and pins can be different size, if you have one oversized roller it could cause shoesto move at different times ---the oversized heads of the pins are for centering the shoes to the drum/axle
Kurt in NJ is online now   Reply With Quote
