Old 08-05-2017, 07:30 AM   #1
PRG999
Default Marvel carbeurator question
I have a marvel carb that I have cleaned and rebuilt. When running I have a small amount of gas weeping from the float bowl vent. How do I stop this?
Also would this be the reason I am getting 10 mpg with it on a properly timed rebuilt engine? I know I have the GAV set properly as when I have the GAV fully closed the motor bucks, at 1/4 open it runs strong.
Thanks
Paul
PRG999 is offline   Reply With Quote
Old 08-05-2017, 09:59 AM   #2
duke36
Default Re: Marvel carbeurator question
Seems like float level is too high or float valve is sticking. What type of float valve? The only one found not to leak for me was the viton tip --with ethanol laden gas. The round ball style didn't seal well. Are all fibre washers in place ? Also check that GAV has leather or (vendor's replacement) rubber washer down at tip. This can make the GAV rod hard to turn unless pulled up a bit.
GAV 1/4 or a tad less open is what I run at normal temps. This depend on needle tip or seat condition. Pull a spark plug and look at color of electrode.
duke36 is offline   Reply With Quote
Old 08-05-2017, 10:44 AM   #3
1930artdeco
1930artdeco's Avatar
10 seems a bit low, you should be in the 15 range. It has a bigger throat than the zenith so you will use more gas.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 08-06-2017, 04:07 AM   #4
PRG999
Thank you for the responses.
I believe all the fiber washers are in place, I will recheck that. The GAV has a new rubber washer.
The float valve is the original one.
I tried to install the round ball one type float valve from renners but it would not seat properly- the unit seemed to wide to properly screw in.
Where does one get a viton tip replacement?
Thanks
paul
Old 08-06-2017, 07:08 AM   #5
jhowes
I get closer to 20 mpg with my Marvel. The original tip lapped in with toothpaste has worked for me.
jhowes is offline   Reply With Quote
Old 08-06-2017, 06:57 PM   #6
Herb Concord Ca
Steiner Tractor sells a viton tipped float valve that may fit your carb.
Herb Concord Ca is offline   Reply With Quote
Old 08-06-2017, 07:05 PM   #7
1930artdeco
Paul,
It sounds like you have the smaller sized float valve. If Thetis the case the you will have to get the one from Steiner's and modify slightly. You just have to shorten it on a grinding wheel. That is what I did with mine.
Mike
1957 Country Sedan
