Old 10-20-2014, 09:24 PM   #21
29AVEE8
29AVEE8's Avatar
Default Re: Hogshead?
Try this, about halfway down they show a hogshead and mention that they make plates to fit along with part numbers.
www.wilcap.com/flathead.html#FHID
Ignorance of the laws of physics does not mean they do not apply to you.
29AVEE8 is offline   Reply With Quote
Old 10-20-2014, 09:40 PM   #22
JSeery
JSeery's Avatar
Thanks 29AVEE8. I made my own, but have people ask me about a source every once and a while. From Wilcox site under: www.wilcap.com/flathead.html#FHID
"This is the bellhousing from the 46 and up Ford truck 4 speed. This bellhousing can be used with the an adapter plate to put a number of different transmissions on to the 59A block or with the 8RT bellhousing to adapt various transmissions to the 8BA block. We have made adapters for the GM "Muncie" pattern transmissions including the T5 (FHT-350 BHA), the Ford T5 (FHT-FT5 BHA), the 64-78 Ford top loader (FHT-FTL BHA)."
Sounds like a custom made part, but if they have the patterns shouldn't be a big deal. Thanks again to 29AVEE8!
Old 02-21-2017, 03:35 PM   #23
schulzcep
I just bought a Wilcap adapter plate and the customer service was awesome! They answered all my questions and have several parts that can make your adaptation easy. I am running a '49 8RT with the Hogshead to a Ford T5, and the adapter plate from Wilcap was like 325. I will try to attach a few pics.
schulzcep is offline   Reply With Quote
Old 02-21-2017, 04:58 PM   #24
JSeery
JSeery's Avatar
Thanks for posting the photos. Is their plate around 1 inch thick, that's what I used?
Old 02-21-2017, 07:36 PM   #25
RalphM
RalphM's Avatar
That's a reasonable price for that adapter from Wilcap.
RalphM is offline   Reply With Quote
Old 02-21-2017, 09:36 PM   #26
Ol' Ron
Ol' Ron's Avatar
I really lov them Hogs heads, they offer an inexpensive way to install late transmissions to the early blocks. Both theT-170 and the T-5 with a simple adapter plate. However, If you want to install a T-5 behind an 8Ba style block, theymake a simple inexpensive adapter plate to do that sa well. It bolta uo the Passenger car bell housing, both cast and stamped steel. Thus you can use the stock clutch linkage. Richard from fla posted a series of pics on this simpet conversion. I have to get the name of the company tat makes the adapter. I used to make them.
Old 02-21-2017, 09:57 PM   #27
donald1950
personally, hogs head is much better than the aluminum addaptors. and remember to use a poilet bushing that is metric as the T5 input shaft is metric. when i did mine i had a machine shop locally make a bushing that fit the ford flywheel and was metric for the input shaft.. using the ford bushing the input shaft will be loose... fit a ford bushing on the T5 input shaft and you will see how sloppy it is.
i have bought several from Dwight Bond. he is still doing them...
[email protected]
1-308-468-5885
i talked with him 4 or 5 months ago.
his is relieved and drilled to use the stock ford throw out collar, spring and throw out bearing assembly.
i do not know how to post a picture of the assembly. i can e-mail several pictures to someone if you PM me....
donald1950 is offline   Reply With Quote
Old 02-22-2017, 10:17 AM   #28
barnfind
Looks like Modern Driveline may have a similar adapter plate for $180:
All adapters:
http://transmission.moderndriveline....p?idCategory=7
Hogshead to Ford T5 83 to 93
http://transmission.moderndriveline....-T-5-7p898.htm
I didn't see any adapters for the S10 T5
barnfind is offline   Reply With Quote
Old 02-22-2017, 10:33 AM   #29
JSeery
JSeery's Avatar
Barnfind, that one looks almost identical to the style I made for mine. Good information, glade to see Ford T5 adapters are being produced!
Old 02-22-2017, 06:45 PM   #30
JSeery
JSeery's Avatar
Donald1950 emailed me some photos of a Dwight Bond adapter. I had thought he was referring to a Ford pattern adapter, but it appears to be a Chevy pattern.
Old 02-22-2017, 06:56 PM   #31
JSeery
JSeery's Avatar
I'll post some photos of the adapter I built, it is for a Ford bolt pattern and very similar to the MDL adapter.
File Type: jpg Transmission Homemade Ford T5Z mount 2.jpg (142.4 KB, 45 views)
File Type: jpg Transmission T5 Z with S10 tail housing.jpg (98.4 KB, 37 views)
Old 02-22-2017, 08:02 PM   #32
Ol' Ron
Ol' Ron's Avatar
Yes, Mdern driveline makes the adapter for the 8BA ford 49/57 bell housing for the T-5, Inexpensive and works like a dream.
Thread Tools
Display Modes
