Old 12-01-2020, 12:47 PM   #1
old31
Default 1935 Thermostats
Are you guys running 160 or 180 TStats?
I just changed a hose a found a 160 in it.
old31 is offline   Reply With Quote
Old 12-01-2020, 06:42 PM   #2
flatjack9
flatjack9's Avatar
Default Re: 1935 Thermostats
180.
Old 12-01-2020, 06:59 PM   #3
VeryTangled
VeryTangled's Avatar
I run Robert Shewman's stats which are made to fit into the upper hose in my 35 and my 36 (using pump-in-head configuration and correct radiators). Pretty sure they're 180's.
Robert Shewman, POB 163, Kimberton PA 19442 six one zero 933 6637 [email protected]
See his advert in the V-8 Times.
-Jeff H
Old 12-01-2020, 07:55 PM   #4
PeterC
PeterC's Avatar
Originally Posted by old31 View Post
Are you guys running 160 in it.
I’m running 180’s
PeterC is online now   Reply With Quote
Old 12-01-2020, 08:07 PM   #5
billybronco1
I'm using 180 degree modern stats
billybronco1 is offline   Reply With Quote
Old 12-01-2020, 09:03 PM   #6
JSeery
JSeery's Avatar
180 much better.
Old 12-02-2020, 11:26 AM   #7
old31
OK, 180 it is.
Does anyone have a 180 NAPA#?
