Old 02-08-2020, 08:46 PM   #1
Big Shark
Big Shark's Avatar
Default 1937 fan belt short
I have a stock 37 sedan with a 85hp flathead. Fan belt is short. P.N. 78-8620-A. Is this the correct part. Got it from Drake. Catalog said it was for a 37 passenger. Thanks Bruce
Big Shark is offline   Reply With Quote
Old 02-08-2020, 10:54 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 1937 fan belt short
Make sure you have a 37 intake manifold, 37 generator and 37 pulley. I am the LAST person to say a remake part is correct, but if over the years, the intake or generator was rebuilt with a larger pulley or whatever it could cause this sort of issue. That part number looks correct to me.
deuce_roadster is online now   Reply With Quote
Old 02-08-2020, 11:24 PM   #3
petehoovie
petehoovie's Avatar
See > https://www.fordbarn.com/forum/showt...+ford+fan+belt
Old 02-09-2020, 08:04 AM   #4
Kerk
Try a B54 . worked for me ! kx
Kerk is offline   Reply With Quote
Old 02-09-2020, 08:21 AM   #5
Big Shark
Big Shark's Avatar
Anyone have a pic of an original intake to compare with?
Old 02-09-2020, 08:34 AM   #6
deuce lover
deuce lover's Avatar
Here is a '36 and '37 intake.The generator sits higher on the '36.
Old 02-09-2020, 09:16 AM   #7
flatheadmurre
flatheadmurre's Avatar
Depends on what pulley is on the generator to...From smallest to largest around is 2 sizes of belts different !
Old 02-09-2020, 09:39 AM   #8
marko39
Just measure it and get one 1" longer. A b54 would measure about 57".
marko39 is offline   Reply With Quote
Old 02-09-2020, 11:33 AM   #9
Big Shark
Big Shark's Avatar
trying to post pics????????
Old 02-09-2020, 11:36 AM   #10
VeryTangled
VeryTangled's Avatar
Picture posting tips...
https://www.fordbarn.com/forum/showt...hlight=picture
-Jeff H
Old 02-09-2020, 11:53 AM   #11
JSeery
JSeery's Avatar
If you still can't get the photos to post, email them to me and I can post them for you: [email protected]
Old 02-09-2020, 01:22 PM   #12
Kube
Kube's Avatar
Drake repop is not the correct length for your '37.
If you locate a NOS belt of that same number, you can easily see the Drake belt is shorter.
If you have the correct intake and generator pulley (3 11/16" diameter), you will be unable to get his belt to fit regardless of what you may try. If you have a later pulley (3 3/16" diameter, introduced late 1940 ) you may be able to tip the generator forward, slip the belt on and get the generator back in place. It's close, but can and has been done.
Old 02-09-2020, 11:05 PM   #13
JSeery
JSeery's Avatar
Here are some photos Bruce wanted posted.
Old 02-09-2020, 11:14 PM   #14
Tinker
Tinker's Avatar
I've had the same issue with my truck. I run one too long now. Car one is way too short. I don't like the generator up so far but it works. Maybe I'll look at the car version.
