Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 11-15-2023, 12:15 AM   #1
steve hackel
steve hackel's Avatar
Default 33-34 steering box, or shaft only, column, drop
City: midlothian
State: illinois
I am in need of a "rebuildable" 1933 / 34 steering box, or only a good
used steering shaft, as mine has been cutoff and another something
has been welded on in its place. I need a full column cover, and either
a 32 column drop to fit my 33 truck dash, or a 33-34 column drop and
I'll machine a shim to use it on my dash. Also in need of both the upper
and lower bearings & races, as these are not currently available from
any of the dealers. Thanks, Steve Hackel [email protected]
steve hackel is offline   Reply With Quote
