04-29-2020, 08:04 PM | #1 |
Intake question
Will a Fenton 3x2 intake accept Holley 94s without any carb mods? Thanks in advance, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain. |
05-08-2020, 09:38 PM | #2 |
Re: Intake question
I'm sure everyone is going to need a lot more info to answer that. But more than likely NO.
05-08-2020, 10:03 PM | #3 |
Re: Intake question
"lonewolf" - I think you're missing the point. I THINK he is asking if 94's will bolt onto a Fenton 3 deuce manifold without interference. I know that they won't on an Offenhauser 3 carb manifold, but will on an Edelbrock. I don't know about a Fenton, but I'm sure someone out there has done it (or found out that it won't work).
I know this, because I once found a Weiand four carb manifold for an early hemi for a great price. Since I had a bunch of 94's, I thought is was a no brainer. Nope, they wouldn't fit unless you removed the front center screw on the back three carbs and then ground down the bosses. I decided that I didn't want to do that, so I spent the next year hunting down some 97's which did fit. If the O/P was asking about function, and not fitment, then I'm all wet. I will admit the question could have been more specific. O/P; what do you want to know? |
05-08-2020, 11:22 PM | #4 | |
Re: Intake question
And this unvarnished truth is the backstory behind the popularity of the 97's over the 94's.
Alan |
05-09-2020, 02:31 PM | #5 |
Re: Intake question
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
