Old 02-26-2013, 04:15 PM   #1
chopo
Default spring kit for rad
i bought a spring/mounting kit today. does onyone hav an illistrastion as how to install it the proper way? thanks Jon
www.jalopyshowdown.com
dont scare me i poop easy
chopo is offline   Reply With Quote
Old 02-26-2013, 05:00 PM   #2
Gary WA
Gary WA's Avatar
Default Re: spring kit for rad
Up from the bottom.
www.whidbeymodelaclub.com
Old 02-26-2013, 06:33 PM   #3
chopo
thanks for the photo. hard for these ol eyes to see. on the front crossember does the spring go between the rad and the frame ??
Old 02-26-2013, 06:49 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
No, the bolt goes in from the bottom up, then the radiator tabs setting on the frame welt (made from various scrap) then the spring on top of the tab, then the castle nut and cotter pin. BTW my original welt between the radiator tabs and crossmember is made from brake lining that has been rolled thin.
Old 02-27-2013, 06:43 AM   #5
chopo
whats the reason for the springs?
Old 02-27-2013, 06:44 AM   #6
chopo
you see if i sit my rad tabs ditrectly on the crossmember the bottom hits the hand crank loop at the spring u bolt. do i have the wrong rad
Old 02-27-2013, 06:56 AM   #7
BobbyG
BobbyG's Avatar
Gary WA - What book is that you have there please ?
Bob
BobbyG is offline   Reply With Quote
Old 02-27-2013, 11:21 AM   #8
Tom Wesenberg
Do you have the radiator pads in place? Mine are about 1/8" to 3/16" thick and fit right under the radiator tabs. Also when Ford started the lower crossmember pads is late 29 they added a 1/4" shim to make up the difference for the remainder of 29 style radiator production.
Old 02-27-2013, 11:24 AM   #9
Tom Wesenberg
The springs allow frame flex without putting stress on the radiator.
Do you have the correct style starter bushing and U bolts?
What time period is you car?
Old 02-27-2013, 02:19 PM   #10
Tom Wesenberg
My 28 doesn't show the raised mounting area of the crossmember real well, but the mounting pad is level with the bottom of the top frame rail. In about September 1929 the mounting pad was lowered 1/4" and an additional shim was added to make up that 1/4". I don't know why Ford didn't just wait until the new taller radiator was out before they lowered the mounting pad.
Old 02-27-2013, 09:39 PM   #11
Gary WA
Gary WA's Avatar
Bob
Les Andrews, Model A Mechanic Handbook.
Old 02-28-2013, 07:18 AM   #12
supergnat
supergnat's Avatar
Chopo,
Here is what is in the Service Bulletins page 452. I hope the .pdf attaches this time.
Supergnat
supergnat is offline   Reply With Quote
Old 03-04-2013, 04:58 PM   #13
BobbyG
BobbyG's Avatar
Noted - Many thanks
Bob
Old 03-04-2013, 06:28 PM   #14
chopo
the bottom of my rad is at an angle. to the one side. when the tabs are sitting of the frame directly the rad his the crank starter bushing
Old 03-04-2013, 09:41 PM   #15
Tom Wesenberg
Yep, that information is in the J/S and states sometime after March 1929 the lower tank was made larger by angling the bottom of the tank. About mid 1929 a recess was put into the rear edge of the top tank to make room for the rivets.
Old 09-11-2019, 01:52 AM   #16
Jeff M
Does this look like the correct tension for the rad springs?
Jeff M is offline   Reply With Quote
Old 09-11-2019, 07:31 AM   #17
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
It likely will be fine.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-11-2019, 12:01 PM   #18
Jeff M
I just wasn't sure if I should crank them down a little more for the head to fit inside the nut and bend the cotter pin over the stud or to bend them around the nut as the attached picture. Since the manuals all say "tighten until you can just get a cotter pin installed."
Old 09-12-2019, 08:17 AM   #19
ericr
ericr's Avatar
does anyone know if the repro springs are stiffer than originals?
ericr is offline   Reply With Quote
