Old 08-20-2019, 09:19 AM   #21
ryanheacox
ryanheacox's Avatar
Default Re: Fumes
Those old carbs do like to leak when given the chance. If you're up for it, it's relatively easy and cheap to rebuild the carburetor and be confident that it will perform well and be leak free. There are a ton of articles about rebuilding them too.
Can you pinpoint where it's leaking from? Is the throat of the carb wet or is it just the bottom?
ryanheacox is offline   Reply With Quote
Old 08-20-2019, 07:52 PM   #22
Apperloo
Apperloo's Avatar
Default Re: Fumes
Thanks eh
24 hrs and the sediment bowl is 1/2 full.
I cleaned up around the carb this morning, and all is still dried up.
It was wet on the bottom.
I have a new gas valve to install, so will change that first, and if all goes well and the leaking stops, it will be onto the next issue
I love a girl and "Ruby" is her name, ChaCha
Apperloo is offline   Reply With Quote
Old 08-20-2019, 07:59 PM   #23
History
History's Avatar
Default Re: Fumes
These carburetors are pretty simple if you're mechanically inclined. I'm glad I accepted the challenge of rebuilding mine. Of course I haven't ran the engine since then but I'm confident it's done correctly. I'm sure there's fellows who could fine tune to perfection and I'll admit I'm not one of them.
If you just need a gasket or a complete rebuild, I say go for it. Lots of information on this site.
If you do rebuild yours make sure you are carful when you separate the halves as the Venturi can become stuck in either or both sides. Mine was broken in two pieces and had been used that way as one side was sanded smooth at the break.
History is offline   Reply With Quote
Old 08-20-2019, 11:42 PM   #24
Apperloo
Apperloo's Avatar
Default Re: Fumes
It’s been a fair number of years, too many, since I’ve rebuilt a Holley double or carter carb, but I will tackle whatever needs doing, at least once
Any thoughts on using Teflon tape or "?? on the pipe thread end of the gas valve threading into the tank? I suspect stock did not use any sealant ....
Old 08-21-2019, 12:16 AM   #25
30 Closed Cab PU
Default Re: Fumes
If using Teflon tape, use the gas/oil resistant type. I believe it is yellow. Not commonly found, may have to search for it. When wrapping it on the shutoff threads make sure the tape does not extend past the threads, which can cause the tape to shred and get into the gas supply.
30 Closed Cab PU is offline   Reply With Quote
Old 08-21-2019, 12:31 AM   #26
30 Closed Cab PU
Default Re: Fumes
Here is links on Zenith carbs. Everythings you wanted to know, and maybe more than you want to know.
https://www.modela.org/
Les Andrews books, and the Rex Reheis Way written by Gordon Biggs are also excellent books.
Old 08-21-2019, 07:38 AM   #27
Apperloo
Apperloo's Avatar
Default Re: Fumes
[QUOTE=30 Closed Cab PU;1790260]Here is links on Zenith carbs. Everythings you wanted to know, and maybe more than you want to know.
Great , that is a lot info for a simple system. Saved to my dropbox. Thanks
Old 08-21-2019, 06:53 PM   #28
Synchro909
Synchro909's Avatar
Default Re: Fumes
To seal any thread, I use a small dab of Permatex No 3 Aviation gasket sealer. Fuel and oil don't affect it and the thread can be undone easily later. I use it on the sump and gearbox plugs, fuel lines, diff housings - everywhere. Similar stuff was around when I was a kid so it has stood the test of time.
Clean up is with a little mineral turps on a rag.
No more leaky joints anywhere.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 08-24-2019, 02:35 PM   #29
Apperloo
Apperloo's Avatar
Default Re: Fumes
I let it drip last night and for sure it is seeping thru the area above the float.
The A has been pretty much sitting for 20 years, so I’m sure that gasket has gone bad.
In the job jar
Old 08-24-2019, 03:52 PM   #30
ryanheacox
ryanheacox's Avatar
Default Re: Fumes
I recently changed all the gaskets in mine and put in a viton tipped float valve. No more leaks for me.
Old 08-24-2019, 07:01 PM   #31
30 Closed Cab PU
Default Re: Fumes
In the job jar
If you are referring to the gasket that is between the bowl and the upper carb body, if the float valve is set and working properly gas does not reach that high in the float bowl, even with a bad gasket it should not have a leak.
Old 08-24-2019, 07:13 PM   #32
Apperloo
Apperloo's Avatar
Default Re: Fumes
Thanks, I will check that
