Old 10-03-2020, 06:21 PM   #1
Detonator
Detonator's Avatar
Default Stewart Warner Parts Source?
I have some older Stewart Warner 2 1/16" gauges I've collected over the years and I'd like to run 'em -- but unfortunately they didn't come with the mounting brackets. I need both the standard height brackets, plus one of the shorter insulated brackets for the ammeter.
I've searched the internet and the usual vendors, and S-W doesn't respond. Is there a source for these old gauge parts? Thanks.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 10-03-2020, 06:49 PM   #2
Tim Ayers
Default Re: Stewart Warner Parts Source?
There is a guy on Instagram named Pat who goes by greyghostgmc. He always has SW stuff for sale and I'm sure he'll have extra brackets.
Some guys also use Williamson's Instruments. Their web address is www.williamsons.com. I'd try them too.
Good luck .
Tim Ayers is online now   Reply With Quote
Old 10-03-2020, 08:00 PM   #3
Russ/40
Russ/40's Avatar
If you can't find them they would be simple to make. It would be easy to make very original looking plated duplicates. Guess it just depends on how much time you have.
Old 10-04-2020, 09:15 AM   #4
TJ
TJ's Avatar
Check e-Bay. Autometer makes gauge brackets for 2 1/16 gauges. If the spacing is correct for the mounting posts the Autometer bracket should work. check e-Bay # 264598840222
Old 10-04-2020, 09:15 AM   #5
deuce lover
deuce lover's Avatar
There are 6 ,3 gauge brackets(3 NOS) listed now on EBAY.$60 - $130.
Here is one for a single gauge although it says for 2 1/8".
https://www.ebay.com/itm/Vintage-Ste...wAAOSwqqNfWpvg
Old 10-04-2020, 04:57 PM   #6
Detonator
Detonator's Avatar
Thanks, but I'm I'm looking for u-brackets, not a gauge panel.
Lots of Autometer brackets available, which I can modify. I'd like to find an S-W insulated ammeter bracket though.
Seabright Hot Rods
Old 10-04-2020, 07:17 PM   #7
TJ
TJ's Avatar
If the Autometer brackets will work you can bore out the mounting holes and insert a nylon bushing from places like Ace Hardware.
