Old 08-26-2019, 03:40 PM   #1
James G.
Default Rear brake drum studs repl
How difficult is it to replace the wheel studs in the rear brake drum? Tools required, etc. Are there some replacement studs better than others?
Thanks for all inputs.
Jim G.
James G. is offline   Reply With Quote
Old 08-26-2019, 04:05 PM   #2
Bob C
Default Re: Rear brake drum studs repl
See Vince's site. http://www.fordgarage.com/pages/swaging.htm
Bob
Old 08-26-2019, 04:53 PM   #3
Charlie Stephens
Tooling and 20 ton press. Find someone that has done it before not somebody that "thinks they can do it".
Charlie Stephens
Old 08-26-2019, 07:56 PM   #4
Synchro909
Synchro909's Avatar
Charlie Stephens
Ditto on finding someone who knows what they are doing.
Do you have steel drums or cast iron ones? I'm not sure new studs are made for steel drums any more but the longer ones for cast iron can be modified to fit. When it comes to removing the old studs, DON'T just drive them out of the hub - you'll ruin it. You must cut away the old swage first, then they will come out with little resistence.
Old 08-26-2019, 08:30 PM   #5
J Franklin
J Franklin's Avatar
A brake shop that works on big trucks can do the job.
Old 08-26-2019, 08:55 PM   #6
Bill G
Bill G's Avatar
My local automotive machine shop who does a lot of our local collector cars did mine when I switched from steel to cast iron drums. He's one of those who does know how to do it and has the press to do it.
Old 08-26-2019, 09:00 PM   #7
chrs1961815
chrs1961815's Avatar
I agree with others here in saying that you have to have the big press or you are just wasting your time.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
