06-10-2010, 11:57 AM | #1 |
Drivers side door lock
Is the door lock on the driver side of my Tudor sedan suppose to be hard to move to lock and unlock Thanks to all
06-10-2010, 12:04 PM | #2 |
Re: Drivers side door lock
Dennis,
It should move rather easy; probable moisture has caused it to build up rust and dry out the slider. The problem is you have to remove the door panel to access the lock which is held in place with two machine screws. Good luck, Ron |
06-10-2010, 12:24 PM | #3 |
07-03-2020, 05:48 AM | #4 |
