10-25-2020, 04:05 AM | #21 |
Re: Oil Breather tube 20 inch flex tube
There's the Stipe one
https://www.specialtymotorcams.com/d...by-control-008 |
10-25-2020, 07:51 AM | #22 |
What about running a hose with a PCV valve over to the intake manifold?
John |
10-25-2020, 02:59 PM | #23 |
I once thought about using a PCV but decided not to . If I used the PCV it would cause the engine to have to reburn the fumes . I figure burning the fumes would slightly weaken the charge in the combustion chambers and help the spark plugs to stay oily and weaken the spark . Too hell with the fumes , I use a Fumaze !!!
10-25-2020, 05:01 PM | #24 | |
10-26-2020, 12:13 AM | #25 |
Not to mention sucking all the byproducts from combustion from your crankcase (unburned gas, water and acids). It's a good thing!
