Old 01-12-2019, 07:47 PM   #1
doug.nichols
doug.nichols's Avatar
Smile Ignition Wire
I have a 12V 1929 roadster with a dual point Mallory distributor and an after market ignition switch. I am trying to determine what type of wire to run from the ignition switch to the distributor.
Thanks
doug.nichols is offline   Reply With Quote
Old 01-12-2019, 08:08 PM   #2
Kahuna
Kahuna's Avatar
Default Re: Ignition Wire
14-16 ga should be fine
Kahuna is offline   Reply With Quote
Old 01-12-2019, 08:37 PM   #3
doug.nichols
much thanks
Old 01-13-2019, 12:48 PM   #4
Jim Brierley
From the ignition switch to the coil, not to the dist.
Old 01-13-2019, 01:30 PM   #5
Badpuppy
Actually, 16-18 ga; 12V requires only half the current of 6V. And you could run it dist - switch - coil if you want, but armor is not a bad thing.
