Old 09-24-2018, 04:55 PM   #1
29er
29er's Avatar
Default Is there a washer on the brass carb adjusting needle seat?
I just received a brass carburetor adjusting needle seat for a Zenith carb from one of the suppliers. It didn't come with a washer, but I'm pretty sure there should be one, right?
Thanks!
Mike
UPDATE: THE ANSWER IS YES! CONFIRMED BY TWO SOURCES:
(1) FORD SERVICE BULLETIN, P 415-416 (see post #12 - by John Buckley)
(2) STEVE @ BERT'S
(Just thought I'd add this update so when I forget next time, I'll be able to find it again!)
Last edited by 29er; 09-25-2018 at 07:02 PM. Reason: I found the answer! Thanks guys!
29er is offline   Reply With Quote
Old 09-24-2018, 05:34 PM   #2
Fred K-OR
Fred K-OR's Avatar
Default Re: Is there a washer on the brass carb adjusting needle seat?
Mike is that the one for adjusting the air? If so I think you are correct and doesn't it need a spring?
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 09-24-2018, 06:42 PM   #3
redmodelt
redmodelt's Avatar
Retracting my post because of information posted by johnbuckley further down. Thank you for the correction.
Old 09-24-2018, 06:50 PM   #4
29er
29er's Avatar
Hi Fred! Long time no see! We think about you every time we go to the coast and pass by your old house.
The one I'm talking about is for the GAV that the gas adjusting needle fits into to regulate the amount of gas going into the carb. The earlier Zenith lower castings have a small brass fitting that screws into there but the later ones don't. I'm pretty sure there should be a washer on it, but can't seem to find a diagram showing that. The repro I bought didn't come with one, so it's making me wonder.
Mike
Old 09-24-2018, 06:58 PM   #5
29er
29er's Avatar
Originally Posted by redmodelt View Post
No it just gets screwed in. No washer for GVA needle seat.
Thanks! Seems it would leak without a washer. Do you put Permatex or anything in it?
Problem is my GVA doesn't seem to work and the car runs fine (but maybe a little rich) with the GVA turned completely off. I'm not running an air filter and the float valve seems to be adjusted ok. The GVA knob is not loose on the shaft so I'm certain the needle is turning. I was thinking the needle may not be entirely seating or the brass seat may be allowing gas to pass by.
Mike
Old 09-24-2018, 09:05 PM   #6
redmodelt
redmodelt's Avatar
Are you sure you have the correct seat installed? The it looks almost the same but would not have the seat for the needle and would fit in the hole/threads. It's the brass screw in piece in the bowl itself.
Old 09-24-2018, 10:17 PM   #7
Gary WA
Gary WA's Avatar
Yes,make sure to remove old washer in there dental pick works good in
www.whidbeymodelaclub.com
Old 09-24-2018, 11:18 PM   #8
29er
29er's Avatar
Many thanks for taking time to post diagrams!
Yup, it's the brass seat as shown:
https://www.brattons.com/carburetor-...edle-seat.html
and not the comp jet that goes in the bowl. The GVA doesn't work. It's all the way off and the car still runs fine. Here's what I'm checking:
(1) air filter can restrict air flow
(2) float valve set too high
(3) leaking needle seat
(4) Comp jet larger than cap jet
It seems that if the needle seat did not have a gasket, gas could leak by.
Old 09-24-2018, 11:22 PM   #9
29er
29er's Avatar
Thanks Gary.
Current score: No = 1 Yes = 1
Old 09-25-2018, 05:28 AM   #10
bigd1101
bigd1101's Avatar
Originally Posted by 29er View Post
Thanks Gary.
Took the old one off....no gasket on the GAV. Got the new one......no gasket included. So......I had the same question with the same results. I just put a small dab of Blue Permatex gasket sealer around the last few threads at the wrench end of the GAV, not the needle end as you don't want sealer plugging up the hole......problem solved. No leaks. With that said, I would have to say I don't think the original design called for a gasket anyway, but a tiny bit of Permatex goes a long way.
Don
bigd1101 is offline   Reply With Quote
Old 09-25-2018, 07:05 AM   #11
JD 1931
JD 1931's Avatar
Yes, gasket is needed on GAV brass seat...
JD 1931 is offline   Reply With Quote
Old 09-25-2018, 07:08 AM   #12
johnbuckley
johnbuckley's Avatar
Oh dear , this may turn out like "what oil do you use"!
Page 415/6 of the service bulletins book [Jan (32?)] gives details of the change over and states that the old style seat and washer ( which we now call a gasket) will be held for service. ( and the contemporary parts list has the "washer" too)
New current score Yes 3, No 1
johnbuckley is offline   Reply With Quote
Old 09-25-2018, 08:03 AM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Washer or no Washer reminds me, two stick figures, made from Welding Rod, on a wood base. The Womans' welding rod hair flowing, as the Man chases her. His body is a SCREW & Hers' is a NUT. The Caption reads, "NO"!!! NOT WITHOUT A WASHER"!!!
Bill Laffin'
"THE ASSISTANT GURU OF STUFF"
Old 09-25-2018, 11:27 AM   #14
29er
29er's Avatar
John: THANKS! (why didn't I think of looking there?). That's pretty definitive! It's interesting that given so many Zenith carburetors had the brass needle seat none of the parts suppliers mention the washer, which has been identified by a specific part number (A-22086).
The suggestion of a dab of blue Permatex is certainly worthy of consideration.
Thanks to all for your input!
Mike
Old 09-25-2018, 11:28 AM   #15
29er
29er's Avatar
Bill Laffin'
And don't forget the anti-seize!
Old 09-25-2018, 04:32 PM   #16
BILL WILLIAMSON
Or maybe LOCTITE--LOL
Bill Bliss
Old 09-25-2018, 06:18 PM   #17
29er
29er's Avatar
Bill Bliss
Bill: Ya made my day!!
Old 09-26-2018, 05:42 PM   #18
Big hammer
X-2
get a bigger hammer tap done
Old 09-27-2018, 06:32 AM   #19
BILL WILLIAMSON
Like Chief sed, "WHEN YOU FIND A GOOD THING, STICK WITH IT"!---LOL
Chiefs' Son
