Old 01-08-2020, 07:03 PM   #1
Warwick
Default Removing rear wheels off axle taper
I guess this is a regular issue. I have a 1914 T and spent a few hours trying to wrestle the rear wheels off the tapers. I'm using the proper hub puller with the nut real tight and giving it a decent whack with a 5 pound hammer but no result yet.
Has anyone out there got the magic treatment ?? Thanks
Warwick is offline   Reply With Quote
Old 01-08-2020, 09:55 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Removing rear wheels off axle taper
Get a bigger hammer, not joking. I know this sounds counter intuitive, but set the side you are removing on the ground and jack the other side up. You then are knocking the axle out of the hub not pulling the hub off the axle.
Old 01-09-2020, 08:08 AM   #3
chuck stevens
chuck stevens's Avatar
heat, drive in circles with the nut backed off about 1/8", puller will work with a bigger hammer.
chuck stevens is offline   Reply With Quote
Old 01-09-2020, 02:44 PM   #4
Warwick
Thanks very much. The seriously bigger hammer really worked. I guess I was a bit timid to make the king hit.
Old 01-09-2020, 06:04 PM   #5
39portlander
39portlander's Avatar
I went through this a while ago, I thought it would be pretty easy.
I borrowed a good size hammer from a neighbor for the job and swore I was going to break something, the second blow against the hub tool and they were loose
39portlander is offline   Reply With Quote
Old 01-09-2020, 06:09 PM   #6
Royce P
Royce P's Avatar
I find it also helps to have both wheels off the ground even if only one is to be removed.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
