Old 10-29-2018, 01:10 PM   #1
hazelhoff
hazelhoff's Avatar
Default Re-torque head
How do you re-torque no.1 headbolt ? Meaning the which is 'under' the distributor, without removing the dist. First ?
hazelhoff is offline   Reply With Quote
Old 10-29-2018, 01:23 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Re-torque head
https://www.brattons.com/head-nut-torque-tool.html
That's what Brattons sells to do the job. A crows foot would probably work too. I've always just removed this dist. though.
Old 10-29-2018, 01:25 PM   #3
30 Closed Cab PU
I take the dist. out. Not difficult. I mark the dist. cam to the plate as a reference for a double check when putting the dist. back on. As long as the cam screw is tight, the dist./motor timing will not change.
There may be other methods, or perhaps a special tool, I do not know.
Last edited by 30 Closed Cab PU; 10-29-2018 at 01:26 PM. Reason: Changed cam nut to cam screw.
Old 10-29-2018, 03:28 PM   #4
29er
29er's Avatar
https://www.fordbarn.com/forum/showt...hlight=snap-on
https://www.ebay.com/itm/Snap-On-Tor...w8XE:rk:3:pf:0
29er is offline   Reply With Quote
Old 10-29-2018, 03:38 PM   #5
WHN
This is the way I have done it for almost 60 years and I’m to old to change. Not much extra work, and you can get a real wrench on that head nut. Enjoy.
Old 10-29-2018, 03:41 PM   #6
Charlie Stephens
On most cars you need to reset the timing when you remove the distributer. On the Model A when you remove the distributer if you haven't rotated anything you can put it back in and not have to retime anything.
Charlie Stephens
Old 10-29-2018, 09:53 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I have the special tool. It makes the job quick and easy.
Old 10-30-2018, 12:18 AM   #8
29er
29er's Avatar
Roger that... besides, who doesn't need another tool?
Mike in Orygun
Old 10-30-2018, 02:19 AM   #9
cpf240
cpf240's Avatar
Is there any significant difference in the tool sold by the major vendors? I'm asking because there is a bit of a price difference between them.
cpf240 is offline   Reply With Quote
Old 10-30-2018, 05:45 AM   #10
old31
I have used the HF crawfoot and the head tool. I prefer the headtool. The headtool might be more accurate due to the design.
Brattons tool look very crude, you can get good deals on used ebay items.
old31 is offline   Reply With Quote
Old 10-30-2018, 08:43 AM   #11
katy
katy's Avatar
A crowfoot at 90° to the torque wrench will give the proper torque.
Old 10-30-2018, 09:28 PM   #12
29er
29er's Avatar
censored!
Old 10-31-2018, 01:00 AM   #13
cpf240
cpf240's Avatar
29er - thank you!
Old 10-31-2018, 03:04 AM   #14
Tom Wesenberg
Ebay often has the correct tool, and even in Snap-On brand.
Old 10-31-2018, 10:28 PM   #15
LEM
LEM's Avatar
Should the retorquing be done when the engine is hot or warm or cold?
LEM is offline   Reply With Quote
Old 11-01-2018, 10:36 AM   #16
abachman3
abachman3's Avatar
Cold.
abachman3 is offline   Reply With Quote
Old 11-01-2018, 11:30 AM   #17
DHZIEMAN
Use a Crows foot wrench!
DHZIEMAN is offline   Reply With Quote
Old 11-01-2018, 08:35 PM   #18
John Stone
John Stone's Avatar
You just can't have too many head nut wrenches.
John Stone is offline   Reply With Quote
Old 11-01-2018, 10:03 PM   #19
Mike V. Florida
Mike V. Florida's Avatar
Yes
