11-13-2014, 03:25 PM | #1 |
1933 can't start after recent restart
Started my model B yesterday..aftee 20 years
ran great. Ran for one hour yesterday and One hour today. Nice solid sound. Today backed out of my garage and motor stalled. Can't restart. Thought out of gas.... Added more gas... gas in fuel pump. While turning over I notice that the ammeter on tyhe insterment panel in not moving at all but dead stationary? Could an electrical component have failed? Did not check to see if i have a spark yet. |
11-13-2014, 03:35 PM | #2 |
Re: 1933 can't start after recent restart
A wise ole' mechanic always told me...."as long as we are talking, it takes two things for a motor to run, gas and spark!" so you know you have gas.........!!!! I'd check the points and accompanying resistors. Figure out why you have no spark!!!!! (if you in fact are getting gas)
11-13-2014, 03:37 PM | #3 |
By the way, if the 33 you speak of is the picture in your avatar?? We have the same exact car too. What's the #of yours???
11-14-2014, 05:41 PM | #4 |
11-13-2014, 05:17 PM | #5 |
Frank,
The starter motor electrical circuit is not routed through the ammeter so that telltale is not indicative of an electrical problem per se. Check for spark next. |
11-13-2014, 05:31 PM | #6 |
12-08-2014, 07:42 PM | #7 |
David, it is a good indicator there is something wrong in the electrical. The ammeter will pulsate when cranking the car because of the points. As the points touch, they ground which will show a discharge for a split second. When they break, it will show a neutral or 0 electrical movement.
http://www.model-a-ford-4bangers.com/ |
11-13-2014, 05:51 PM | #8 |
I'd suspect something came loose like an ignition switch terminal nut or coil terminal.
Lonnie |
11-13-2014, 06:03 PM | #9 |
[QUOTE=FrankWest;980291.......Did not check to see if i have a spark yet.[/QUOTE]
Next time you post, please tell us you have checked for spark.
Alan |
11-13-2014, 07:31 PM | #10 |
Ignition points in long stored vehicle often fail quickly after a restart due to the oxide on the contact faces. If you have power to the coil, but no spark, or weak spark, the distributor needs to be repaired and set up on a machine.
11-13-2014, 07:48 PM | #11 |
I think BINX nailed it.
11-14-2014, 04:09 AM | #12 |
"the distributor needs to be repaired and set up on a machine."
If the points ARE fouled, why would the distributor need "repaired?" ... and why set up on a machine? It's a Model B.
"Remember that when it comes to intelligence, half of all of us are below average." |
11-14-2014, 06:18 AM | #13 |
I think Supereal was referring to a V8.
Just clean the points up and make sure the distributor rotor (or cam) is nice and smooth. It is true that points can wear quickly after long storage due to roughness on the rotor. Of course it could be something else, but that is an easy thing to try first. Mart. |
11-14-2014, 08:17 AM | #14 | |
It is freezing out here! |
11-14-2014, 10:53 AM | #15 |
The machine reference was for the V8. My trifocals weren't working, I guess. Even so, be sure that the body and bushing is OK when replacing the points. The problem could also be due to a weak or open condenser, or a loose distributor mount that allowed it to move.
11-14-2014, 11:40 AM | #16 | |
NO SPARK! Where can I find a photo of the key electrical components. so that I can check the connections. I have several ford books on the 1933, 1934 It was running beautiful and sounded like a new car and then just went. I suspect something like the coil? is there a coil? |
11-14-2014, 03:47 PM | #17 |
Didn't I post one (an illustration, not a photo of the four-cylinder electrical system) earlier for you?
Coil failures are not unknown, although much rarer with an original 4-cylinder coil than with a V-8 coil of the same era, and you have a coil. The original location was on the upper vertical portion of the firewall, more or less in the center, on the inside of the car. It shows in a photo that was posted along with the above referenced illustration. |
11-14-2014, 05:44 PM | #18 | |
But, my ammeter has stopped moving since the problem. Befire the ammeter was jumping around during starting and when the car was running. Where shoudl I look next if i find no loose wires? |
11-14-2014, 06:49 PM | #19 | |
I recently had my computer crash and I am using another computer.... I will check under the fuse question...I think that is where you posted it. Thanks... It was great...The photo was exactly like my car. Last edited by FrankWest; 11-14-2014 at 07:02 PM. |
11-14-2014, 07:01 PM | #20 | |
