03-07-2024, 05:00 AM | #1 |
heater motor b6a78527b
trying to get a heater fan motor for my 59 non a/c galaxie there must be one for sale some where
also how do i remove the interior rear view mirror cant pind how to get to the screws please be patient with me i,m new to classic cars |
03-07-2024, 09:23 AM | #2 | |
Re: heater motor b6a78527b
1956/ FORD - RECIRC FRESH AIR - 1/4in Shaft Dia - B6A 18527-B 1959 FORD - FRESH AIR - 5/16in Shaft Dia - B9A 18527-A GIGGLE The Correct PN and you should come across one.
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 03-07-2024 at 09:36 AM. Reason: THE USUAL - ADVANCED CRS |
03-07-2024, 03:05 PM | #3 |
what is the correct part number for a 1959 ford galaxie heater fan motor the car does not have a/c will any other year motor fit or is it specific to that year thank you
03-07-2024, 04:10 PM | #4 |
To removed the rear view mirror you have to remove the trim around it, so the sun visors and the long trim between the mirrro and the sunvisor
03-07-2024, 04:26 PM | #5 |
IF you can find a parts store that will take the time, they may have a book showing all the available motors with dimensions. Be sure to get one that turns the correct way.
Another possible source is a Tbird parts supplier. They have fan motors which may be the same as a sedan. Did you check with a suppliers like Dennis Carpemter, Kanter
48 Ford Conv 56 Tbird 54 Ford Victoria Last edited by paul2748; 03-07-2024 at 04:36 PM. |
03-07-2024, 09:44 PM | #6 | |
How to ID and the PN's are in my previous post. Most likely you can find either NOS if you SEARCH the PN.
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
03-10-2024, 09:02 AM | #7 |
Thank you for your replys i have tried mr carpenter , how do i remove the two grill retaning bolts from under the headlight / ive taken the headlight brow off but theres no access , owm shows nothing about access to the 5 top bolts
03-10-2024, 09:05 PM | #8 |
See if the ILL shows large enough to show detail -
