05-12-2017, 07:48 PM | #21 |
Re: What transmission parts do I need?
What RonC said in #11. They are easy to rebuild IF necessary..just change the oil and replace with a good 600w and try it out. If it only has a true 5000 on it it should be good.
If not then you can do a bunch more! Brian W. |
05-12-2017, 11:03 PM | #22 |
I don't know but for some reason, an edit created a duplicate post.
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 05-12-2017 at 11:14 PM. |
05-12-2017, 11:06 PM | #23 |
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 05-12-2017 at 11:13 PM. |
05-12-2017, 11:10 PM | #24 | |
With very few exceptions no reproduction parts are made as well and to the same specifications as the original. To rebuild something just because one wants to often leads to substandard operation and "food money" thrown away. If you feel you absoululty must replace the insides, here is a good article; Henrys-Transmission-Traps.pdf and Transmission-Assembly-List.pdf
05-13-2017, 08:06 AM | #25 |
I want to at least check the condition of the bearings. I got the car from my dad, who grew up with them and spent his whole life working on them. He told me that he thought a bearing was going bad in it. I drove it for a short distance when I got it, and I could tell right away that the throw out bearing was bad, but I didn't go far enough to see/feel anything else.
The thing is, I'm not sure that I trust the 5000 mile speedometer. Although the car is in great shape, I am finding some things with a lot of wear, and some that look brand new. |
05-13-2017, 08:30 AM | #26 |
The throw out bearing only turns when you push the clutch in if it's adjusted correctly. Does it have an inch of freeplay and only make noise when you push the clutch pedal down? If you take the tranny apart to check the bearings, I'd clean them in gas, blow them out with compressed air, then put a couple drops of light oil in them and see how they spin and feel. |
05-13-2017, 11:35 AM | #27 | |
Bill Lazy
05-13-2017, 11:49 AM | #28 |
If you only heard the throw out bearing, another option would be to remove the inspection cover, drill a small hole in the side of it and using a grease needle pump a few shots of new grease in, clean around the hole with solvent (careful not to get any in the bearing) and fill the hole with a dab of JD weld or RTV silicone. Could quite it right down and then you could drive it a bit and see if anything else is noisy , just an idea
Sent from my iPhone using Tapatalk |
05-13-2017, 12:53 PM | #29 |
ALSO, serviceable T.O. bearings, along with many other sealed bearings, can be re-packed with a wheel bearing packer. That grease will be far superior to the original manufacturers' grease, which is usually like Vaseline! I think it's called PLANNED OBSELESCENCE--(SP?)
Bill Cheep
05-13-2017, 07:09 PM | #30 |
An original T/O bearing gets new grease when you pump some grease into the sleeve grease fitting.
If this is truly a 5000 mile part, then it should be original. About 1985 I thought it would be a good idea to pump more grease into my front CV boots on my VW diesel Rabbit, so I used the hypodermic grease needle for grease to pump some in. This was a bad idea, because even though the hole it poked was little more than a pin hole, the boot tore open within 2 months, and I had to replace it. |
05-14-2017, 09:52 PM | #31 |
Didn't read all the posts, so I apologize if this is a repeat. At least the 3 needle bearings.
Good enough.. Isn't. |
05-14-2017, 09:59 PM | #32 | |
"If it ain't broke, fix it till it is.."
