Old 11-08-2020, 04:07 PM   #1
Ramjet47
Ramjet47's Avatar
Default 1941 11-A Distributor Cam Plate
Is the Detent in the outer edge of this 11-A cam plate there for a reason or is it it a blend out of damage?
File Type: jpeg 3A9C5AB4-5637-4FFB-9A61-809B317D2D5D.jpeg (19.6 KB, 47 views)
Ramjet47 is offline   Reply With Quote
Old 11-08-2020, 04:40 PM   #2
35fordtn
35fordtn's Avatar
Default Re: 1941 11-A Distributor Cam Plate
That is a blem, I’ve run across a couple like that and the plate needs to be replaced as it will rip the leather pad off the vacuum brake plunger
Old 11-08-2020, 04:56 PM   #3
Ramjet47
Ramjet47's Avatar
It took me a while to get an 11-A core to rebuild and I’m unsure I’lll be able to get another here. Do you see any problem with welding up the damage area and reprofiling to original contour? I am in New Zealand at the moment waiting for the Australian Queensland borders to re open, great place to isolate.
Old 11-08-2020, 05:14 PM   #4
cadillac512
cadillac512's Avatar
That's sure what I'd do. If you can match and polish,it should work as good as ever.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 11-08-2020, 05:15 PM   #5
KiWinUS
KiWinUS's Avatar
Ramjet I believe that would work if it’s perfect workmanship. Then polish with no rough spots. You couldn’t be Quarantined in a better place. Eat all the fish n chips you can for me please.
Cheers
Tony
