Old 05-08-2020, 08:59 AM   #1
rhschwerdt
Default Foaming coolant
Is foaming coolant (about 50/50 anti-freeze/distilled water) an indication of a blown head gasket?
rhschwerdt is offline   Reply With Quote
Old 05-08-2020, 09:01 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Foaming coolant
Typically. It could also be a crack in the head or block where combustion gasses are entering the coolant.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-08-2020, 09:12 AM   #3
TMarsh
I had foaming after 10 miles at 50 MPH. Looked like whipped cream. Made me sick. No overheating indicated. Had cheap antifreeze, tap water, and off brand stop leak. Drained it all put in 50/50 Prestone, distilled water. No problem since. I suspect it was a mixture of what I put in the radiator that just got whipped into a foam, went all over the windshield and hood. Stopped and put 1/2 gallon of water in and continued 35 mile trip. No problem since.
Just my personal experience.
Hope you discover something as simple.
TMarsh is offline   Reply With Quote
Old 05-08-2020, 09:39 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Foaming is an indication that the water pump is mixing air into the coolant. This may be the result of:
>Coolant type or additive;
>Restriction in the coolant inlet route to the pump.
In many cases a thermostat in the coolant outlet hose to the radiator solves the problem. Another cure is run a stock radiator cap instead of a flip-top cap.
Bob Bidonde
Old 05-08-2020, 12:01 PM   #5
ryanheacox
ryanheacox's Avatar
Yep. The air getting whipped into the system is likely combustion gas leaking past the head gasket. Any idea which head gasket your engine has on it?
ryanheacox is offline   Reply With Quote
Old 05-08-2020, 12:22 PM   #6
Bruce_MO
Simple test... fill the radiator to the top. Disconnect the fan belt so the water pump won't turn. Start the engine and look for bubbles at the filler neck. Any bubbles are an indication of a blown gasket or crack as Brent points out. Don't do it too long; she'll get hot pretty quick.
Bruce_MO is offline   Reply With Quote
Old 05-08-2020, 02:13 PM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Does it really matter if the pumps not turning? Seems like you would get bubbles either way?
Old 05-08-2020, 03:18 PM   #8
Bruce_MO
Stopping the water pump from turning reduces the chance of what Bob pointed out... air leaking in as the source of the foaming.
What you should see is nice big bubbles coming to the surface, especially when you speed up the engine a bit and create more pressure leaking thru the defective gasket surface.
Old 05-08-2020, 08:33 PM   #9
rhschwerdt
Thanks to all. I'm pretty sure it's a blown head gasket or crack in the block or head. I'll try a couple of these tests and see what happens.
Old 05-08-2020, 11:06 PM   #10
daren007
A leak down test will tell you everything you need to know.
daren007 is offline   Reply With Quote
Old 05-08-2020, 11:18 PM   #11
The Master Cylinder
The Master Cylinder's Avatar
A lot of good suggestions. The first thing I would do before tearing it all apart is re-torque the head. It may prevent a lot of heartburn. Then proceed from there. Good luck.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 05-09-2020, 10:00 AM   #12
30 Closed Cab PU
An alternate test for exhaust gas in the coolant - Block Test Kit, tests the air in the upper radiator tank for exhaust gas. Can easily do yourself, or check around at radiator shop or your local independent shops. Usually cheaper on amazon.
https://www.napaonline.com/en/p/BK_7001006
30 Closed Cab PU is offline   Reply With Quote
Old 05-10-2020, 09:01 AM   #13
ryanheacox
ryanheacox's Avatar
That's the kit I have. Here is what a slight leak looks like, a bad leak should turn the fluid yellow.
