Old 01-08-2021, 02:17 PM   #1
Pete Fl/Wi
Pete Fl/Wi's Avatar
Default Windshield glass removal 39 coupe
Cracked windshield in my 39. PO set glass in with looks like black silicone. Do I break the glass and pull the glass pieces out? Or is there trick? I have the windshield out of the car.
Glass is safety type
Thanks Pete
Pete Fl/Wi is offline   Reply With Quote
Old 01-08-2021, 03:08 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Windshield glass removal 39 coupe
Might try cutting the silicon with a razor blade to remove glass or take it to a glass shop.
Paul in CT
Old 01-08-2021, 04:52 PM   #3
marko39
You need to separate the two windshield halfs which is necessary . Then see if you can work the glass out.
marko39 is offline   Reply With Quote
Old 01-09-2021, 01:59 AM   #4
rich b
rich b's Avatar
If indeed the glass was set with silicone or urethane instead of setting tape; you may very well have to break the glass out and remove in pieces to avoid damaging the windshield frame.
Old 01-09-2021, 09:22 PM   #5
Bluedot
Ow! Glad mine is a 40 and not a 39. =)
Bluedot is offline   Reply With Quote
Old 01-09-2021, 09:30 PM   #6
Graeme / New Zealand
Graeme / New Zealand's Avatar
Go over to Irontrap Garage on youtube. They have just put up installing glass in a 39 windshield.
https://www.youtube.com/watch?v=nD3WwsA8Ea4&t=28s
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 01-10-2021, 01:51 PM   #7
alanwoodieman
I had a 36 and some one had put silicon gasket maker in the frame, I used a squirt bottle of gas to loosen it up to pull frame pieces off
Old 01-10-2021, 02:22 PM   #8
johndee138
johndee138's Avatar
I often use a heat gun to remove caulking and silicone. It may crack the glass unless you shield it with a piece of aluminum flashing or something like that
johndee138 is offline   Reply With Quote
Old 01-11-2021, 01:45 AM   #9
swoopNZ
MEMBER EMERITUS
The small screws can be a nuisance sometimes if they break off while undoing them.
swoopNZ is offline   Reply With Quote
