07-16-2021, 11:30 AM | #1 |
Electric power steering from a Saturn Vue into '54 Ford Customline
07-16-2021, 12:05 PM | #2 |
Re: Electric power steering from a Saturn Vue into '54 Ford Customline
Very interesting. I would imagine it would require an update to 12 volts and an high amp alternator in the process.
07-16-2021, 12:44 PM | #3 |
Interesting adaptation but no mention was made on how the shifting of the transmission was addressed.
Did a little research and found that any column shift vehicle needed a new method of shifting gears. In most cases a floor shift would be needed.
07-16-2021, 05:35 PM | #4 |
No holes cut in the tunnel for a standard transmission.
07-16-2021, 06:20 PM | #5 |
Not at the time the photo was taken.
And it appears to be an automatic equipped car (no clutch pedal) Being a column shift, a way to shift will have to be addressed (such as a floor shift)
07-16-2021, 09:05 PM | #6 |
07-17-2021, 12:09 AM | #7 |
Poetry...
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
07-17-2021, 08:14 AM | #8 |
Further FYI: Computer controlled 5.0/AOD out of a '93 Mustang including factory EFI.
07-18-2021, 10:59 AM | #9 |
I'm looking for some information about using electric power steering on a 50 Ford with a flathead. Haven't had any luck yet. Already solved the shift problem with a T-5. Anyone?
07-18-2021, 05:45 PM | #10 | |
10-24-2021, 04:50 PM | #11 |
there is a 3 part video on this on youtube using saturn vue power steering into a shoebox
10-25-2021, 09:24 AM | #12 | |
Cheers Here's mine detailed on the FTE site. https://www.ford-trucks.com/forums/1...ing-build.html
1949 Ford F-47 with a '51 8BA Flatty, GM TBI fuel injection system, and a grey shop cat, Spot. Last edited by Kilohertz; 10-25-2021 at 09:30 AM. |
