Old 07-09-2021, 10:29 AM   #1
Russell Reay
Default Horn repair
No sound from my aoogah horn, so will disassemble, clean, and reassemble per Les Andrews. His sketch shows two felt oil washers on the motor--one at each end. Mine had only one, and I lost the other during disassembly. Is there a common household product which could be used to create new ones--old felt hat, Sorel boot liner, etc?
Russell Reay is offline   Reply With Quote
Old 07-09-2021, 10:42 AM   #2
Russell Reay
Default Re: Horn repair
One more question--instructions say to clean field windings with compressed air. Any reason why I can't use solvent?
Old 07-09-2021, 11:01 AM   #3
Badpuppy
Plain old felt. Just to retain light oil against the shaft.
Old 07-09-2021, 11:02 AM   #4
Badpuppy
Solvent may eat through the lacquer insulation, causing short.
Old 07-09-2021, 11:02 AM   #5
frank55a
Yes, depending on the solvent you use it might loosen or remove the installation on the windings. If so then you are SOL, and the windings will need to be replaced.
frank55a is offline   Reply With Quote
Old 07-09-2021, 11:10 AM   #6
Russell Reay
Thanks for the warning
Old 07-09-2021, 03:03 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
Mass airflow sensor cleaner so far hasn't eaten any parts I have tried it on, use it to clean contaminated transmission computers
Old 07-09-2021, 03:05 PM   #8
Garcia
Garcia's Avatar
And please follow the advice Andrews gives about being gentle with the armature. I wasn't, and one of the wires broke. I was lucky to find a rusty but working horn on an auction site, so I put its armature in my horn and I'm back in business.
Garcia is offline   Reply With Quote
Old 07-09-2021, 03:15 PM   #9
Russell Reay
I am being very careful. The wires appear very fragile, and I don't wish to break any of them
Old 07-10-2021, 02:39 PM   #10
Ivan in southeast va.
Ivan in southeast va.'s Avatar
This is what a bad horn looks like. I bought a new one from A&L before the pandemic.
Ivan in southeast va. is offline   Reply With Quote
Old 07-12-2021, 08:51 AM   #11
Russell Reay
Update- Followed all procedures, reassembled horn, and it works, but it is not nearly as loud as it should be. Maybe it just needs adjustment, but Is wire size a culprit? I tested it with ~14 ga jumper wires
Old 07-12-2021, 11:59 AM   #12
Jacksonlll
Jacksonlll's Avatar
Any voltage drop is a problem for the horn motor.
Old 07-12-2021, 12:12 PM   #13
Badpuppy
Probably adjustment. Maybe worn ratchet. #14 is plenty.
