Old 04-02-2021, 08:57 AM   #1
Neshkoro
Neshkoro's Avatar
Default Vacuum Wiper motor removal
My 1930 Model A has a vacuum wiper motor that does not work. It appears that someone removed the vacuum connection to the manifold and installed an air horn. I want to get the wipers working again. I reconnected the vacuum line but it still does not operate. It seems the motor is buried in the header. I started removing the fabric on the header. All I can see under the fabric is the wooden board that makes up the header. There seems to be no access to the motor. Am I missing something or just not digging deep enough? I didn't want to keep removing stuff if I'm not going at it the right way. I have a few Model A repair books but none address the removal of the motor. What are your thoughts?
Thanks for your help!
Neshkoro is offline   Reply With Quote
Old 04-02-2021, 09:03 AM   #2
Stingray70
Stingray70's Avatar
Default Re: Vacuum Wiper motor removal
The vacuum motor should mount to the OUTSIDE of the window frame. It will be plainly visible. Remove the 2 screws from the inside of the windshield frame.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 04-02-2021, 09:08 AM   #3
Stingray70
Stingray70's Avatar
It should take 2 minutes with a screwdriver to remove it. ( if you go slowly)
1930 Standard Coupe
Old 04-02-2021, 10:25 AM   #4
chap52
chap52's Avatar
There are kits available to rebuild these units and also reconditioned ones. I rebuilt the one on my 30 Tudor and was not satisfied with the results. But I live in Arizona and rain is not something we generally drive old cars in. It's more of a newsworthy event than a common one.
Like said, two screws it's off. there is a solid vac line that runs to the top of the windshield and is attached to the ww unit by a short line/hose. Chap
Old 04-02-2021, 12:27 PM   #5
Neshkoro
Neshkoro's Avatar
I agree that the motor is mounted on the outside of the windshield. The 2 mounting screws come from the inside of the car to mount the motor. I need to look again. It seems the screws aren't visible from the inside of the car. When sitting in the driver's seat, I do not see the screw heads. Do I need to tip the windshield up to access those screws? I live in Illinois and the car is stored in Wisconsin. I won't be up there until next week when I can take a look. I must be missing something obvious.
Old 04-02-2021, 12:57 PM   #6
Bob C
You need to open the windshield to see the screws.
Old 04-02-2021, 01:23 PM   #7
JayJay
Yes, you need to push the windshield open. At the far end of the sliders, then lock in place with the hand nuts. You will be able to get to the screw heads with the windshield fully open.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 04-02-2021, 05:58 PM   #8
Neshkoro
Neshkoro's Avatar
OK, then. Thanks. It was perplexing me! Now I got it. This is a great site. many helpers for us newbies!
Old 04-10-2021, 10:53 AM   #9
Neshkoro
Neshkoro's Avatar
OK, I removed the wiper motor as you guys suggested from the open windshield. That was easy. It's really difficult to rotate the arm by hand.
Time to disassemble and rebuild!
My question is Who designed those screw heads on those screws that hold the wiper motor together?!?!?
Henry Ford must have been mad at his wife that day!
Old 04-10-2021, 12:06 PM   #10
GRutter
GRutter's Avatar
Original Trico screws. The parts vendors such as Snyders and Brattons offer an inexpensive tool that fits those. Otherwise needlenose pliers have always worked for me.
GRutter is offline   Reply With Quote
Old 04-10-2021, 03:05 PM   #11
Neshkoro
Neshkoro's Avatar
I’ll check both sources. Are those the sources you usually use for parts?
Old 04-11-2021, 02:43 AM   #12
Stew Masche
Stew Masche's Avatar
They are both great sources for parts. When you get the wiper open, you may find the paddle that travels back and forth in the housing is dried out. That has happened to me more than once. If you saturate the paddle wit oil, so that it swells a bit, you may not have to do anything more with it, it’s worth a shot.
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 04-12-2021, 08:25 AM   #13
Neshkoro
Neshkoro's Avatar
Good thought Stew. Thanks
Old 04-12-2021, 08:30 AM   #14
jetmek
With any luck .... worst case the pot metal is blistering
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 04-14-2021, 08:11 AM   #15
Neshkoro
Neshkoro's Avatar
I just finished disassembling, cleaning and installing all the rebuild parts. Next step is testing. That'll be a couple of weeks until I can get to the testing.
Old 04-19-2021, 01:26 PM   #16
Neshkoro
Neshkoro's Avatar
Hi Guys,
I need this part for a vacuum wiper motor.
It's the Rocker, home. The fiber piece that the spring attaches to.
I hope you can view this jpg.
Thanks
