04-20-2024, 07:37 AM | #1 |
Carb Rebuild
Gentleman, Does anyone know of the guy in New York that rebuilds the carb on a 33 model 40? I believe it is a Rochester
Thank You |
04-20-2024, 08:10 AM | #2 |
Re: Carb Rebuild
Contact Charlie NY, 716-662-9159 Western part of NY, he rebuilt my carb plus lots of others on this forum.
04-20-2024, 08:20 AM | #3 |
Re: Carb Rebuild
Or Uncle Max, Stromberg wiz. He is allowed to post on here. Probably will chime in. Uncle Max, to the courtesy phone!
I dig coal, which provides motivation for EVs. |
04-20-2024, 08:22 AM | #4 |
Re: Carb Rebuild
Charlie Schwindler in Orchard Park, NY The Carb is a Detroit Lubricator?
04-20-2024, 08:28 AM | #5 |
Re: Carb Rebuild
My bad, assumed the Model 40 referred to carb.
04-20-2024, 07:57 PM | #6 |
Re: Carb Rebuild
04-20-2024, 07:58 PM | #7 |
Re: Carb Rebuild
Thank You !
04-20-2024, 07:58 PM | #8 |
Re: Carb Rebuild
Thank You
04-20-2024, 07:58 PM | #9 |
Re: Carb Rebuild
All Good !
04-21-2024, 05:38 AM | #10 |
Re: Carb Rebuild
Stromberg also made a model 40 duel downdraft carburetor used on the 34 Ford V8.
04-21-2024, 11:45 AM | #11 |
Re: Carb Rebuild
04-21-2024, 01:45 PM | #12 |
Re: Carb Rebuild
04-22-2024, 06:34 AM | #13 |
Re: Carb Rebuild
In 34 Ford used both the 40 and 48. The two Carbs were identical in outward appearance, with the difference being the inside of the top and center sections. At sometime near 35 Ford had Stromberg mark the die casting "48" to distinguish Ford Carbs from Carbs used by other car Mfg. due to Fords rebuilding program.
04-22-2024, 07:46 PM | #14 | |
Re: Carb Rebuild
Pretty sure '33 and '34 Ford cars were model 40's. Sal |
04-23-2024, 07:40 AM | #15 |
Re: Carb Rebuild
carbs.
The "40" designation came from the Ford part number prefix for 1934 automobiles. The 40's are very similar to 48's with the exception of the upper idle channel circuits. Outwardly, it's near impossible to tell the difference. ______________ This partial quote is from none other than Uncle Max. It was from a few years ago.
04-23-2024, 11:40 AM | #16 | |
Re: Carb Rebuild
Sal |
